Meet the seller
Seller: richardc1161( 421)
Feedback: 100 % Positive
Member: since 17-Apr-05 in United Kingdom
( I was recomended this site on Ebay for filters )
Are you fed up with the increasing cost of diesel?
Then make your own fuel out of used vegetable oil!
This listing is for a 25 micron filter – I am recommending that these 25 micron filters be used as part of the filtering process ie before my 10 micron and before my 5 micron filters.
*******Please see my other listings for 5 and 10 micron filters*********
***NEW! 1 micron filters now available***
PLEASE NOTE! Most diesel engine systems have a fuel filter that cleans down to 10 micron. Filtering down to 5 microns means that you will already have 'cleaned' the Waste Vegetable Oil of any harmful particles before putting it in your tank. Pouring the oil through one of my 25 and 10 micron filters will extend the life of the important 5 micron filter.
Most takeaways are just chucking their used vegetable oil out, so why not help the environment and your wallet by pouring it through one of these 5 micron filters and then straight into your tank!
I have a Discovery and an old Range Rover classic, both with the 200 tdi engine, and both are running on a 70/30 (Veg Oil to diesel) in the summer; a 50/50 mix in the winter. On long runs this ratio goes up to 90/10!
In response to the many questions I’ve received…………its as simple as this:
Get an old oil drum and cut a 7" circular hole in the top of the lid. I have also fitted a rotary hand pump in mine.
Make sure the drum is clean and free from metal off-cuts before using it and ensure that you file off any rough edges on the hole to protect your filter (once you have a ‘used’ filter, you can trim the material away and use its plastic rim as a ‘liner’
Insert the filter sock (the rigid plastic rim will hold the sock in place).
To increase the life of your 5 micron filters, first pour your oil through a fine metal sieve to get the lumpy bits out! Put the WVO back into the container and give it a week to ten days to settle; you will see a ‘cloud’ forming at the bottom.
I have previously used j-clothes and old pillow cases placed in a metal strainer for the next phase, but found these to be painfully slow compared to a 25 micron filter sock.
So, now carefully pour the clear oil through a 25 micron filter sock, leaving the cloudy stuff in the bottom of the container. If you put in a search on ebay for ‘siphon pump’, you will find very cheap (0.99p plus post) hand operated pumps for cleaning fish tanks, wine making etc. I have found this to be a slow (6.5 litres per minute) but sure method of removing the clean oil.
At the risk of turning this into a blog, many of you have also requested 10 micron filters. It sounded logical, but I wanted to try it myself before selling them. Sure enough, their use DOES improve the life of the 5 micron filters so I have now incorporated one into my system. I have also been asked for 1 micron filters! To be honest, I won't be using them myself because I drive a tractor disguised as a car, however I now have these in stock.
So, once through the 25 and 10 micron filters, my oil then goes through a 5 micron filter suspended in the lid of a 200 litre drum where it is stored ready for use.
I am frequently asked “how long will my filter last?”. The answer depends entirely on the quality of the oil you are getting, whether you sieve it first, how long you settle it for, how carefully you pour/siphon it off and whether you filter it through your old jeans/ a 25 and 10 micron filter etc before it goes through the final 5 micron filter!!
If you are running out of old jeans and/or getting grief from a family who are fed up with you taking all their pillow cases then please see my other listing for 10 and 5 micron filters!
Please note: These are high quality HEAT SEALED filter socks, unlike some out there which are stitched........please do be wary of using these inferior quality filters as the oil just pours through the stitching holes making your 5 micron filter a little bit pointless!!
These filters are 16" (40cm) long and have a diameter of 7" (18 cm). Longer (32") filters are out there on the market, but I don't like them because the take up half the depth of the storage barrel.
A note of warning, please ensure that your vehicle has a Bosch and NOT a Lucas fuel pump. Research on WVO/SVO use shows that the Lucas pumps do not run well on Veg Oil - I would rather that I lost a customer than you lost your fuel pump!
Full details of your threshold limits for paying duty on your oil can be found on this link:
http://www.hmrc.gov.uk/briefs/excise-duty/brief4307.htm
In simple terms, at 20 mpg you can cover 11,000 miles per year, 25mpg / 14,000 miles per year, 30mpg / 16,500 miles per year, 40mpg / 22,000 miles per year, 50mpg / 27,500 miles per year. The above figures are rounded off, but give you some idea of much oil you will need to use before worrying about Customs and Excise.
The boring bit:
* I prefer PayPal and will accept cheques/postal orders for bulk purchases only.
P&P costs are £1.57 for 1 x Filter, please add 43p for each additional filter required.
Please note that you CAN combine postage on 25, 10 and 5 micron filters!
* I will post these filters First Class and I always keep records of posting.
* I'm sorry, but we do not offer local collection.
* I will post abroad, but please contact me for P&P costs BEFORE bidding!
* I will always endeavour to post items out to you within 2 days of payments clearing.
Thank you for looking........happy filtering
