Everything posted by jtylr
Thanks for clarifying @Tony Brooks I think I will replace this with the double mounting type and fit agglomerator + sedimenter and run 1 line to engine and 1 to heater as this minimises number of filters. It will all be easily accessed so can tap the tank if any problems occur.
Nope, but I will do now! Just let 210ml of water out of it, thanks for the tip! So I have separator -> filter -> injection pump, gravity fed. As gravity fed does this remove the risk of engine sucking air/fuel from the line to heater as mentioned by @Tony Brooks further up?
Yes, that’s the injection pump. I stopped by UCC when bringing the boat north and Jonathan Hewitt kindly spent some time talking me though the engine. Is there better options for filter(s)?
Thanks for the replies. @Alan de Enfield My day tank should be called a half day tank really, as it holds about 4l. I am used to topping up before starting a journey. Dip pipe is right at the bottom. @Tonka I am fairly dense when it comes to engines, I assume the lift pump is where the pipe/hose are leading to from the filter? I will attach a photo of the whole system shortly - I can’t resize it to under the attachment limit on my phone
Please can someone help with the following: I have a CAV filter with what I think is a ‘spare’ inlet/outlet which is currently fed by a day tank. I am planning to install a diesel heater dropped down into the swim (currently in the middle of prepping for paint) - can I just connect the fuel line to the no.1 outlet and utilise the same filter to save me tapping the tank?
Advice on buying a 75% finished sailaway
jtylr replied to Spudwynk's topic in Boat Building & Maintenance
I bought a boat this time lasted year and surveyor flagged the height of vents during survey. Due to the likely cost of correcting them I chose to patch them up and had a new locker fabricated on the stern deck. Old locker is to be repurposed as a water tank directed to hot taps, wm + shower, once I can be bothered to climb inside and sort it out. -
Perfect, thanks for the tips. I had planned long sweeping bends (pipe bender) already minus the tees off to radiators. Heater to be situated at stern end in the bottom of a cupboard, rads dotted down one side and header tank up in a cupboard after the last rad. I’ll increase the size of the flow + return but stick with copper for the pipework, just for peace of mind it will not deviate from the installed slope and bends.
I have done quite a bit of reading and found some useful diagrams etc. on here and elsewhere but still have a couple of questions. I am planning to use a Refleks 66MV cold furnace to run 3 small rads to heat approx. 20ft of cabin space: 1. As the coil in the heater is 15mm, is there any point is using a larger diameter pipe for the feed/return? 2. Has anyone used Yorkshire tectite fittings in a nb and are they suitable for dealing with vibrations? 3. Do tight bends/angle matter in the teed off feeds to the rads? I have attached a very professional drawing of what I have in mind to hide the pipe work, but don’t mind dropping straight down and having pipes on show if this could cause problems. 4. how much rise is it possible to get away with where the return (running just above floor) meets the heater? The ideal location requires about half a foot so the heater can be positioned above the engine bilge.
off I trot to buy a diesel genny then 😅
Potentially, I have the impression it was a fairly well built/specced boat when built 40 odd years ago…
Can anyone shed some light on what this tank is for at the bow of my NB please? It’s empty/bone dry, definitely not connected to the diesel tank above it (because I assumed it was and now have some diesel to clean from the bilge I had almost finished prepping for paint 😅) 1.5 inches tall so some kind of skin tank perhaps? Thanks
You are correct! What is best practice for the twin alternators? some kind of set up where once the starter battery is fully charged both of them get pointed to the leisure bank?
Looks like its been in there a while to me ? Surveyor did some basics checks of oil etc. and it runs fine, so I will do a few things like clean up surface rust on moving parts, replace the lagging + tidy up the cables in the short term. Further down the line may head to UCC and get it benched/rebuilt while I sort out the engine bay. Can anyone explain what's going on with the 2 belt setup? I just ordered replacements and the guy at the end of the phone was unsure why I needed 2 rather then 1.
oops. ignore
Thanks for confirming not an Allen. so I have looked through the images I could find of Black Prince's and found a v. similar bow with the integrated fender but none of the other bits bits such as integrated handles etc. Re: hire boat. The engine has only 1047 hours on it, this ties in with seller saying it has lived in a marina most of its life + I sent a video of engine to a friend of a friend who services/rebuilds them, who said doesn't look like any reason to doubt the clocked hours. Plot thickens
Absolutely no idea. 'paint cabin exterior' is currently scrawled in a bic somewhere toward the end of my very long arm.
Quite a few distinctive/nice features so hopefully someone who knows their onions can ID the builder. 2x diesel tanks built into the sole: 1 at the bow and 1 midship, which is pumped to a smaller 'day tank' at the Stern. Bearers are 80mm angle sections with approx. 600mm spacing. I'm not really concerned if it is/is not an Allen, but I do like the boat so it would be nice to know.
Quick update - Survey was pretty good. Gas locker has been condemned + the blacking was a sh*t job, some minor pitting on baseplate to be filled so coming out in July to sort that out maybe go with exposure over bitumen. Not entirely sure it is a Les Allen as the baseplate/hull are 6/5 but they have retained their thickness in most areas + it’s a nice little boat so I’m happy. I emailed the Allen Register a while back for an ID but think the site may be dead. Is there a suitable place on the forum I could post some pics to maybe identify the builder as it would be nice to know.
Not a trailer... I won’t be moving 20 sheets at a time, but bike is rated to 70kg although becomes a bit of a pig to ride once you get up to 50kg. Have a mate with a workshop who can take deliveries and where I can cut into boat-friendly sizes too. Power situation does need more consideration though.
Hi Bod, I’m going to buy a copy of the BSS regs. Did see a link in another thread but forgot to bookmark it. will dig it out. wasn’t aware of the RCD will look into this thanks. I’ll drift in and out occasionally, but will be staying in Hertfordshire for a while.
This is what I’m currently looking into - I have seen some (admittedly quite expensive) panels that claim to be considerably better in low and filtered light + likely to go lithium-ion for batts. Problem with corded is the current draw on start up, which means I need an inverter with a huge KW rating to fulfil that single purpose. More research is required here so I won’t derail the thread any further and will post in the appropriate area once I have done more some reading.
I converted a century old shell of a 350sqm industrial unit into live/work art studios mostly on my own some years ago, how hard can a 20sqm boat be? ? On a more serious note, I accept that some mistakes will be made. I understand there are specific considerations that need to be made vs. working on land, and I’m currently just doing a lot of reading/research to try and minimise very expensive ones. When I do make one I can learn from it, put it right, and in a few years hopefully be in a position to give a bit of guidance those who find themselves in the position I’m in now.
a few solar panels, large battery bank + inverter, and charging my second set of batteries at work. Trying my best to avoid buying an LPG genny.
