Hi,
This may not be the correct forum to discuss but as my nb has a BMC engine I thought I'd post it here. I have a recurring issue with foreword thrust (recurring because it also happened last year). Boat is fine when I start out but after about 30 mins, speed drops until barely any forward movement. Reverse thrust is good. When I stick it in reverse and crank up the revs, when I put it back in foreword it regains thrust. But it drops down again after 15-20 mins. If I switch off the engine and leave it for a while, when I start up again, foreword is fine. But then drops off again. Things to note:
1. weed hatch is clear
2. RCR engineer has been out to check it. As it was over night, engine had totally cooled down etc and engineer couldn't find anything wrong - foreword and reverse thrust strong.
3. RCR engineer checked and slightly adjusted the cable;
4. RCR engineer checked gearbox oil - right amount in there just dirty. Gearbox was replaced in May this year by qualified engineer.
So we carried on but same problem has recurred.
Just wondering if anyone has had a similar experience?
Thanks
Andrew
