jckent
    London
  • Occupation
    retired
  • Boat Name
    Day dream
  • Boat Location
    cruising
jckent's Achievements
Explorer
Explorer (2/12)
0
  1. I have recently returned from doing this waterway starting from the Wigan end. The Lancashire end is very weedy with sections completely covered from side to side for some length. The main problem with this was that rubbish got trapped in the weed and then got stuck on the prop. Beyond Foulridge all seemed ok at present. The Wigan flight caused problems - two pounds were completely empty when we got to them and we had to wait for water to be passed down the flight. We were stuck for 3 hours! There were also a couple of gates that needed more than one person to open. The flights further on were supposed to have volunteer lockkeepers to assist should you sign up online for assistance - I signed up for the first two flights but saw no keepers so not sure this system is worth continuing with - it raises false hopes. The section to Skipton is really beautiful and there are plenty of rural mooring available. Swing bridges are a real problem should you be single handing - the operation is from the offside and there are generally no landing areas on that side, so one cannot get back on the boat! There are about 30 of these bridges between Skipton and Leeds so I pity single-handers doing this section. Hope this helps anyone contemplating this canal.
  2. Despite the criticism I have found the 4 head rotating handle AG Walsh windlass has done me well. I have tried many others but have always found some lock that requires another windlass - shorter or longer, or larger or smaller holes! This covers all those options saving me from returning to the boat for an alternative. The rotating handle also helps when doing dozens of locks in a day!
  3. jckent
    Airtags
    They are indeed Apple items! Similar to tiles as they use Bluetooth but with the much larger Iphone population they are more efficient at finding items, or so they say. It seems a cheap way of checking that an item is not stolen or if it is, where it is now. They are really meant for luggage, wallets, handbags etc but are also useful for cars - if you forget where you have parked it can lead you there for example. Just thought someone might have used one on their boat.
  4. jckent
    Airtags
    Can't find any reference to these so has anyone used them for keeping tabs on their boat? Although it is unclear from what I have read they seem fine for finding things but if leaving the boat for an extended time I see that they emit a noise after 3 days should they be moved. Anyone have experience of this?
  5. Yes it is but there is no water supply to the tap or loo. Don’t know if this is permanent but suspect it is. Yes but I had passed them when I ran out. Don’t know about the caravan park, wouldn’t they only deal with smaller bottles?
  6. Hello all. Crooke Marina seems only moorings now. In Wigan we moored by the Dry Dock and got Boss Gas to deliver to the boat (small delivery charge). The reason for having both bottles empty was that we swopped them over in Liverpool Albert dock and was going to replace at next convenient point. The fuel boat in Liverpool doesn’t have gas. Unfortunately we must have had a gas leak because the second gas bottle ran out 4 days later on our way back to Wigan. There seems to be very few facilities between Wigan and Liverpool. I thought one of you might have known of one not marked on my maps. Any way thanks to Boss Gas for good service. Now on the Bridgewater at Worsley, no water at this waterpoint and ablution block very unwholesome.
  7. Couldn’t find one.
  8. I am at Parbold heading towards Wigan and have run out of gas! Does anyone know if Crooke Marina sells gas, or the next available place where I can get some? thanks.
  9. Yes, I think maybe our best bet is the 'buddy system' on the L&L. Birmingham is a middle point - we want to go via the Oxford on to the Thames then to London then North to Rugby - we have 21/2 months. Going into Liverpool is something on my wife's wish list. She also has going past the Houses of Parliament on that list but I am resisting unless it is on someone else's boat ! Call me a coward if you must...
  10. Thanks all. We are pretty experienced boaters, having had our present boat for 8 years now and having used it about 2 months each year - but it is not totally reliable since it is used by others when we are not using it. When we take it over we have to sort out any problems before becoming confident. So a tidal river is not going to be an ideal testing ground. Thank you for the info re the Standedge tunnel guage - our boat is somewhat taller than standard so that might be a problem?! Maybe the Leeds and Liverpool all the way to Liverpool might be a better option. The only downside of that is the heavy swing bridges which from past experience can be almost impossible to get moving... Perhaps they have been improved since we did them last, about 10 years ago?
  11. thanks, any pointers?
  12. Thank you all. Maybe the Huddersfield will be the choice since they are narrow locks - which we prefer. We are starting off in a couple of weeks so hopefully there will still be some water left for us.
  13. Thank you all. I should have said that I really wanted to go over the Pennines but there are about 4 options - via Skipton, via Rochdale Canal, via the Huddersfield the either Macclesfield or Bridgewater canals. I know there are lots of either locks and/or swing bridges and a very long tunnel depending upon route so what I would like to know is which of these routes would be easiest for us. I ask because we are both recovering from medical conditions that have set us back a bit and we are both in our 70s now so not quite so sprightly any more. We have done the Skipton to Wigan route before and loved it but to get there involves many heavy swing bridges. Any advice would be welcome. Incidentally the Trent does sound interesting!!!
  14. Thanks I have heard that mooring on this route is difficult, is that not so?
  15. Thanks My boat is a 57ft narrowboat
