Neil2 - thanks , air intakes on the side with shutters interesting , but like you said shut when running makes no sense for me , as when running against the tide , the engine will be working much harder than
on the canal and my deck will be sealed against the elements salt water etc. So this is just when I need air into the engine room. Aread2 - Yes your prob right although current will be minimal
when I do runs across the Humber I run a minimum boat 12V Nav lights and engine ignition only, but your right the alternators are another large heat source.
Eeyore - sounds a good design, think I would prefer over side vents , Cereal tiller - Yes I am thinking of one bilge level near engine block/alternators and one at the top- hot air exhaust , just read someone
added a 12v fan on the exhaust pipe to add air pressure (but dont want to make complex if I dont have too + another thing to worry about if the fan stops mid Humber)
