Tatguy
Everything posted by Tatguy
  1. I didnt see this befor it was built in 86 taken from crt website When we purchased the boat we had a prof boat builder do a fit out Then if some remember we had engine problems so we put a recon engine and gearbox in so it's a 2 1/4 landrover marinised engine We have over 30k in receipts Who ever buys this boat will realise what works been done When purchased it was striped rebuilt repainted and spotwelded to sort any pitting all electrics and insulation new So to original question we think it's a great boat
  2. I just had the panel made and put on Ive checked the temp sender on engine is working by putting in a kettle on and temp going up Do they need to be calibrated? I just thought you had to replace
  3. I have an old landrover engine its just had new parts fitted New water pump Alternator Starter motor New clocks (as you can see in the pic) All belts and filters It has no thermostat It does have a bowman water cooler that is raw water cooled The coolant is in and no leaks Water comming out is cold Engine although hot isnt overly hot But water temp is 115 !!! It doesnt rise any more but it is worrisome Any help would be appreciated Ps it doesnt loom like a head gasket as there is no brown stuff in head or in header tank
  4. Got it sorted now thanks it was the gauge Tat
  5. It only drops down if i touch wire from switch to earth Other than that nothing happens Its on constant weather there is wire on switch or not
  6. Ok i have a 2 and a quarter landrover series 2a When i turn on ignition the oil pressure gauge goes full even without engine running When i start the engine it remains full Any ideas?
  7. As promised the pics of the repair Im having a few more jobs done to the engine as I've found a guy that works on any engine Will do a new topic when done with befor and after
  8. Ok have found a place and there fixing now will post a pic when done
  9. Ok so i now know my engine is a series 2 2and a quarter engine Thanks for your help with that guys my next issue is my lug has broken of the manifold ive added a pic do tou know of any company that referbs welds them its alloy so im having issues finding someone Thanks in advance
  10. The old ones were painted green with the engine!! Ive purchesed a few spares now again thanks everyone
  11. Ok thanks everyone its a landrover 2.25 series 2 Thanks so much for your help new plugs went in and she started ?
  12. Have done and thanks for your help ill let you know how it goes
  13. I dont know a friend just took it to a garage came back and said its broke Im in no way an expert butim gratfull to have found out its a landrover 2.25 ill goto motorparts take the old and see if we can now sorce the replacments or ill but the ones you put a link up for thanks so much
  14. Tested at a garage by a friend negative to earth type
  15. Yes i understand the smoke issue was just giving all the info It would take ages to start the engine and ran the battery down twice it would try to start but cut out But once going it would be fine
  16. It looks like that rlwp what engine is it for as it looks simular
  17. It started giving of black smoke having issues starting stopping but once warm ok Then it wouldnt start checked everything then took glow plugs out checked them they dont get hot at all
  18. Just to clarify the plugs dont work We have removed and tested We need to replace just need to know what engine it is I do appreciate all the help ?
  19. Ive checked the plugs they dont heat up The only thing they say on them is Core 330 1.7v 3D or 30 Thanks Also i did get the bmc plugs ill show a pic of mine next to it
  20. Do you know what one ive broke down need to fix glow plugs need the name of engine for parts
  21. Ok ive been told its a bmc 1.5 then a bmc 2.2 now im told its not a bmc Please help
  22. Thanks I didn' move in the ice but were we was froze in it looks like it' just come away as it melted But thanks for advice I'll reblack next year
  23. Ok so I blacked my boat last year did 3 coats I'e moved a lot and tend to touch up as I go to the parts of boat I can touch up My question is after this load of ice it looks red around the waterline were it' come off will this be ok till next year as I'm booked in March
  24. I did say in my first post the flue and baffle plate was clean I do that very regularly Again thanks for the help Tat
