Agaze 8800A adjustable sensitivity flashes and bleeps when find leeks I've never used one and found this easy to use. If getting 1 don't pay out for next day delivery mine came next day on free delivery
Finally got it sorted could not locate the leak using a spray (too small) nice gas technician man offered to come and have a look for £78 p.h........got a gas sniffer £28 from amazon on most sensitive setting found leak at two joints gave them a little tighten problem solved retested and safety certificate in the bag.
Thanks again for all the suggestions
Thanks again I will .pick up some spray tomorrow and let you know how I get on. The leak is minor gas safety chap didn't think it a risk but had to rightly fail us.
cheers
treddie
Thanks all I'm on the Calder and Hebble at Horbury near Wakefield. Soapy water sounds like a good starting point. Gas runs to boiler, cooker and fridge think I will start at locker and work my way through the entire system. Got to walk the dog first so sorry if I don't reply to posts for a while
My boat safety inspection has identified a minor gas leak somewhere in the gas system
option 1 pay a gas technician to find the leak and fix it
option 2 spend £50 at screw fix for a gas sniffer and try to do it myself
option 3 find a friendly local boater (Wakefield area) who owns a gas sniffer who is willing to lend it to me or would run it around the pipes in return for a few drinks.
If you could recommend any one for option 1 or fit the bill for option 3 I'd love to hear from you
cheers
treddie
Not sure if put this in right topic please feel free to move. Calder and hebble navigation outside horbury basin remain well to tow path side recent heavy rain boats are becoming stuck on silt
My seaflo water pump (SFDP1-033-035-41) has gone mad sometimes not working after using the shower now not stopping. I think its time to replace it. Seaflo dont seem to have a good reputation without spending a fortune what make would people recommend? My current one works at 35psi through an accumulator do I need to look for 35psi again?
Any help much appreciated
I am replacing my leaky pancake vent with a mushroom. As the diameter of the mushroom is less than the old vent I will be left with 4 screw holes in the roof. Can anyone suggest how to fill them and make it water tight before a coat of paint.
Cheers
Treddie
Currently on Calder and hebble thinking of going up towards sowerby bridge. How far can I get before will need to turn around because of repair work?
Cheers
Treddie
