umpire111
Everything posted by umpire111
  1. At wits end and looking for inspiration. Have a Whale Watermaster 1214B which has been working well. It has now started cycling in every few minutes. I have checked all taps, prv, etc and there are no leakages on outlet side. Have serviced the pump after speaking to Whale, no change. Have also tried another pump whic h I know is working fine, it still cycles in! Any ideas PLEASE
  2. Many thanks for this well argued response and am taking your advice, have used Fertan and now applying primer, ready for bilge paint this weekend. Pete
  3. Someone has said they use a floor paint from Screwfix instead of specific bilge paint when painting the bilge, much cheaper of course. Anyone done that?
  4. Someone suggested painting the bilge with a floor paint from Screwfix, would welcome views as ir does much cheaper then Danboline
  5. We shall be leaving Sawley Marina on Tuesday 30th May, two of us on boat
  6. Many thanks, looks favourite. We plan to be thru prior to Festival weekend. Castle gardens looks good
  7. Leicester mooring, want to stay for 2 nights in early June in Leicester, anyone recommend safe moorings please?
  8. Serviced last year but the engineer, thanks for all above
  9. It starts then stops after a few minutes however has run on a couple of occasions. Fault code 052 is showing now. Anyone know someone in Nottingham or Sawley who will repair?
  10. Erbespacher problems, any experts out there? Have a D5-WSC and after running for varying times it just cuts out. The timer seems to be ok. There are fault codes 52 and 30 showing, have seen what they mean but they add little. If I switch off the heater and turned it back on it works ok then again shuts off at varying time intervals....any ideas?
  11. Re the ekorness stress less, which models did you buy as concerned re width
  12. Thanks for responses, are Wilsons the only one doing these narrower chairs?
  13. 2016 was st Crick Show and tried some soft captains swivel chairs on a stall, these are for the lounge. Took details and planned to buy about now but have lost sellers details, can anyone help please
  14. currently have carpet down in the NB but as there is now a dog so thinking of changing to a wood type flooring. We have been recommended Karndean which is a strong vinyl type but this seems expensive at £50 per metre fitted. They have to put ply down first. Can anyone recommend any alternative or any views re Karndean, is it slippery when wet, clean easily, durable?http://www.karndean.com/en-gb/floors/look/wood
  15. thinking about fitting a drawer into our 11 year old narrowboat. Have found this one but seems a bit pricey, anyone know of any others or recommendations? http://www.jacksonsleisure.com/caravan-motorhome/fridges/compressor/waeco-coolmatic-cd30-under-bench-drawer-fridge/
  16. That's great, been going thru site for last hour. Sure I can find something there
  17. Need to replace existing car radio in boat. Can anyone advise, are car radios still the best. Am looking for a dab radio that takes a USB or sd card to play MP3 and if it could Bluetooth to play music from iPhone that would be great. Have looked at amazon but there are so many. Only have two speakers to output to. Thanks and all advice welcomed
  18. Thanks for that comprehensive response, can new bearings be easily purchased. Can I ask what the boat yard charged for the whole job., my boat will be out of the water.
  19. time to replace as play has got too much, the boat is coming out of the water soon, any idea how to remove and replace bearing- are they a standard bearing? never done this before but I know that the handle is bolted on in two places if that helps to identify type- cheers.
  20. many thnaks, took your advise and did two windows in your timescale of two days! proper job.
  21. further: I know I will have to replace the wooden battens that the windows are screwed into- can I replace them from the outside or will I need to remove all the internal paneling to access them?
