floatsyourboat
Everything posted by floatsyourboat
  1. I'm confused, how does the starter battery get charged if everything is going to the domestic bank?
  2. Thanks for all the tips everyone I certainly have a few techniques to try now. Don't you find the tinder in white spirit leaves a smell?
  3. Thanks. Would the motorcycle battery fall foul of the BSS?
  4. My smev all in one hob/oven/grill has a block on the back for wiring up the ignition. There is no 12v near the cooker so I am wondering if it would be possible to wire up a small battery like a pp3 for the ignition and if anyone else has done this? Thanks.
  5. I'm about to move aboard this weekend and wondered what's the best technique to get a fire going with coal from a cold start? Thanks.
  6. Hi I have two alternators one wired to the starter and one wired to 4 x 110 amp batteries I want to split charge.
  7. Does anyone have a picture of how these relays are wired up please as I've bought a 120amp relay but my mechanic friend said its only for split charging one battery/alternator.
  8. Thanks for the replies. It's a sure cal. It's just slightly dripping from the top of the element ( right in the middle) I thought turning it upright may have eased the drip! Thanks.
  9. I have a calorifier that's installed laying down. Is it possible to change its position to standing upright? Thanks.
  10. I am currently on the lower peak forest past Manchester.£65 don't sound bad if someone could give me step by step instructions online though! Thanks.
  11. Any idea who I could ask or how much this interface would cost?Thanks.
  12. It looks like the battery monitor.Will I not be able to dial down the amps with this? Thanks.
  13. I've checked the inverter model I have it's a Multiplus 12/3000/120 and it has a little round screen attached via a cable so I assume this is the remote?
  14. Tesco and some other super markets have recycling bins. If anyone's interested how about creating a google map with recycling points for boaters that everyone can share and add to?
  15. That sounds top nice one I shall be getting that (;
  16. The engine is a low hours Isuzu. I'm starting to think spending £500 on solar rather than a generator might be a better idea!
  17. Thanks.Is there a way I could dial down the charger it's a 3kw Victron ?
  18. I am thinking about getting a suitcase 2kw kipor generator as I have been told just running my engine in neutral will cause glazing! I have an inverter with a 120 amp charger built in can anyone explain to me how plugging a generator into my shore power socket will work? Will the generator have to be left running for hours? Is it safe to have a generator on a bracket off the back as the manual says it should use an earth rod? Thanks.
  19. I have had a friend who is a mechanic remove the sterling charger and connect the batteries to each alternator, so one to the starter and one to the domestic bank. I showed him the 120amp relay and he's scratching his head a bit in terms of connecting it up. He is concerned my cables are heavy and the connectors on the relay are just little spades and a couple of bolts! Are there any pictures we could refer too please?
  20. Where do people think the nicest places to live on a canal boat are in the UK?
  21. That's interesting so what kind of satellite dish do you use and do you have to have a separate box to go with it?
  22. Where is the best place to mount a TV ariel on a narrowboat and what on ? I am unsure if I should get some kind of long pole to fix an ariel or get a satellite dish? The front of the cabin roof has a good 6 inch lip on it that would get in the way so I am wondering if the cabin side is advisable ? Thanks.
