jeb
Everything posted by jeb
  9. If its for the sake of accuracy then please be accurate.
  10. Sadly, further north from you (Durham) people are getting killed for it.
  11. [ A diagonal cross of silicone from corner to corner of each tile should suffice. Start at the bottom and let each row set before doing the next one up. Then you can grout with a flexible grout. http://www.geocel.co.uk/product.aspx?id=80&pr=dctm To speed the job up you can put a couple of blobs of glue from a hot glue gun between the diagonals of mastic and this will set rapidly and hold the tiles until the mastic sets allowing you to proceed as quick as you like.
  13. In that case it must be very good fishing ,thanks for the tip. Where is it ?
  14. Do they by any chance have their cars parked directly behind them ? If so its generally called lazy. Even on lakes it is the car park swims that are occupied.
  15. All I want is that when I ring first and ask them if they can confirm they have a certain item in stock and when I arrive just over an hour later having travelled god knows how many miles and used god knows how many litres of fuel I damewell expect the sod***g item to be there and when its not I get hmmm a little saddened. Not for the first time today but most certainly the last trip to a well known Midland Swindlers. Rant over.
  16. What size brass bolts would you use to fix these to the side of your boat ? The reason I ask is because of the simple ease in which I sheared the head off a 5mm bolt this afternoon. I was going to use the same bolts to fix the toe steps but now have doubts about their suitability.
  17. Milliput Thanks for that , looked it up and it sounds just the job. A friend of mine has some so will try it out tomorrow. If it fails ie : hole to small for it to grip well then I will redrill and tap all 4 as Phill has suggested. Thanks to you both
  18. Hi all Does anyone know of a filler that I can drill and tap a thread in once set. Managed to shear the head off a 5mm mushroom vent bolt this afternoon and made the hole slightly larger drilling the stud out. It was the suns fault because I dont do things like that. Cheers
  19. Its a good idea but just isnt workable.Take a look at EA meeting from 2006 scroll down to item 769 and you will see how many clubs have an interest. Where does one stretch end and another begin ? Each club will have its own fishery rules ,how will you know what they are ? Some clubs will restock on a regular basis at their own expense and would strongly object etc etc etc. http://www.environment-agency.gov.uk/commo..._oct_1782460.pd
  22. I would still give shield batteries a ring as Idleness has already said. I called them looking for some 135A Deep cycle batteries. I am considering the 140A batteries that they offered for £97 + vat and a 105A starter (664) for £59 + vat. The 140A (ref 31DC36 )batteries are American made and can be seen here.Must admit I dont know what a type M terminal is. Nothing to loose by a phone call. http://www.renewablestore.com.au/catalog/i...products_id=935
