Hi! I Would like advice please on boarding for my engine room build please? Where would I buy suitable boarding to stand on and does It have to be fireproof?
I am using high temperature sealant 1200c on my stove but it gives off a bluish smoke. I followed instructions and let it cure for 24 hrs. The smoke is coming from the top plate join to the stove pipe
Ok, thanks for your replies! Much appreciated!
A typical machine draws 10 amps for heating and I have five 110a
Leisure batteries. Will that be ok or will that suck my batteries dry?
Hi! Is it possible to play mmo games over WiFi personal hotspot and Is 4G good enough please? Are there any solutions or will we have to wait for overall stronger signals?
Hi everyone! Thanks for all your replies! The boiler is working ok now. It was the cold weather that was the cause!
Water temp not as hot during winters of course but not lukewarm as it was this year, hence my topic posting!
Ok, thanks for your suggestions! I haven't been on the boat for a while and gas and water was turned off for the duration.
I don't have a manometer but didn't know gas is under pressure in instant water heaters
Hi! The water is only being heated to a mild temperature.
Burners are ok and pilot light doesn't go out and I have a good water supply! Heater did make a noise like a gushing sound
It is a Morco D61e about 5 years old
Hi! Thanks for all replies! it is a D61E Eco. I'm going to try descaling But looks like I'll have to take it off the wall so I can get the fluid to run around the pipe
It is a possibility that temperatures are low but I've always had hot
Water
Hi! Water in my morso heater isn't getting hot enough despite burners are alight and knob turned up to max! heater is about 4/ 5 years old.
The pump and accumulator tank are working ok!
Any ideas please?
Ok, I'm aware of materials going up in flames, and thanks for all the advice but it was the speed of the flames spreading!
I put topic in 'equipment' because although flammable gowns may not count, cookers do!
Yes, ok! ok! Cotton being flammable since the dawn of time but I wrote post soon after the incident! I could of used a better headline I suppose!
Or are we going to discuss when fire was discovered and the origins of cotton?
A word of 'warning' about highly inflammable cotton, and in my case a bathrobe/gown which caught fire while lighting the gas stove.
Fortunately with quick thinking I managed to smother it and extinguish the flames which quickly spread!
Avoid at all costs!
Hi! I don't have a problem with my back boiler boiling! I have a 4k squirrel
Stove. I run 28 mm pipe in a circuit along the whole length of the boat
With four rads attached. I also have an expansion tank + a 12v pump
Which I rarely use. Sometimes the pipe circuit is enough and therefor
Close rads but no boiling back boiler,
