jenevers
Everything posted by jenevers
  1. Gasp! But how,why, when, where, who?
  2. I'm thinking better to disconnect neutral cable before live. Am I right?
  3. For the record, my bolt croppers worked a treat. Good clean even and square cut.
  4. Cor! Want!I'll try croppers once then jubilee/saw if croppers no good.
  5. Why the huge price differences between different 4 zone hobs?
  6. Do you have a copy of their Yard Book? Thanks Btw am I the only person on this forum who can see a hauntingly evil face in your avatar? Look at it from a distance, squint and a spooky face will become apparent!!!!
  7. A difference in what respect? I'm talking about the riveted boats?
  8. Yeah. I really meant is there a common fault on these battery chargers. I was hoping there might be a little glass fuse that had blown, but there isn't.
  9. I have a Mastervolt Mass 12/80 charger which doesn't work. Before I send it back to Mastervolt might there be a repair that I could do?
  10. That's interesting.I wonder if the British Isles Transprt "A" Shortboats and the Longboats (Ambush etc) on the L&L, were built using copper bearing steel, as they worked across the Mersey and had round Chines.
  11. I've read that a quick, temporary fix for a small leak in a diesel tank is to rub a bar of soap (!) into the area where the diesel is weeping. Right or wrong? Which of the many proprietary brands of sealants on the market, could anyone recommend as a good sealant, to use on a leaking water tank, that would adhere to WET metal, if such a product exists?
  12. Did Yarwoods tend to use " copper bearing steel" as a rule?
  13. Trojans advice re charger size, is 10-13% of battery capacity, so if I get 6 x T105s (675Ah at 12v) a single 80A charger should be ideal. No need to use another 80A charger in parallel.
  14. Looks like only 150 Mb for the second half. Lost signal a few times so didn't quite see 40 minutes worth. Not bad.
  15. Thanks I'll risk watching the second half of the France/Ireland game then. I only have 6 Gb left this month.(Satellite dish took a tumble)
