onionbargee Posted September 22, 2012 Report Share Posted September 22, 2012 i have aquired a Shoreline 12v fridge with a Danfoss R134A compressor, the pcb control unit is brain dead, i want to test the compressor to see if its worth salvaging for parts, what is the right way to do this ? i want to give it a good test run, say 12 hours, Will it be happy to run direct from a battery ? ( i'll stick a fuse on it ) and if you can tell me which of the 3 pin terminals correspond to which windings that would be good. All i can download from Danfoss is the fault codes from the control unit, no good to me. Link to comment Share on other sites More sharing options...
smileypete Posted September 22, 2012 Report Share Posted September 22, 2012 i have aquired a Shoreline 12v fridge with a Danfoss R134A compressor, the pcb control unit is brain dead, i want to test the compressor to see if its worth salvaging for parts, what is the right way to do this ? i want to give it a good test run, say 12 hours, Will it be happy to run direct from a battery ? ( i'll stick a fuse on it ) and if you can tell me which of the 3 pin terminals correspond to which windings that would be good. Er, no, it's basically like a 3 phase motor and won't run on DC. Best you can do is check the resistance between any of the 3 terminals is the same, to show the windings are likely OK. cheers, Pete. ~smpt~ Link to comment Share on other sites More sharing options...
by'eck Posted September 22, 2012 Report Share Posted September 22, 2012 (edited) i have aquired a Shoreline 12v fridge with a Danfoss R134A compressor, the pcb control unit is brain dead, i want to test the compressor to see if its worth salvaging for parts, what is the right way to do this ? i want to give it a good test run, say 12 hours, Will it be happy to run direct from a battery ? ( i'll stick a fuse on it ) and if you can tell me which of the 3 pin terminals correspond to which windings that would be good. All i can download from Danfoss is the fault codes from the control unit, no good to me. R134a is the refrigerant gas used in the compressor. Chances are its a Danfoss BD35 or maybe BD50. Check here for fault diagnosis test. Edited September 22, 2012 by by'eck Link to comment Share on other sites More sharing options...
