Breals Posted August 18, 2005 Report Share Posted August 18, 2005 (edited) I will be needing some power for lights, TV, laptop, stereo and 12v mini fridge... without a hook-up, and (with the price of diesel about to shoot up) I was thinking of getting a wind generator. Any thoughts on brands and models to use? I have a budget of about 500 quid. My research so far suggests the Rutland 910/913 series. Nuggets of wisdom, pertinent digressions and helpful asides greatly appreciated. Edited August 18, 2005 by Breals Link to comment Share on other sites More sharing options...
Gary Peacock Posted August 18, 2005 Report Share Posted August 18, 2005 Without you really fancy a bit of DIY the Rutland stuff is probably the best it is expensive but it does work. On the DIY front you could have a look at these- http://www.otherpower.com/17page1.html http://www.bwea.com/you/byo.html http://www.green-trust.org/wind.htm If you do go down the DIY route keep us informed, I always fancied a go at it but never had access to the equipment to manufacture one. (I now have but don't have the time!) Link to comment Share on other sites More sharing options...
bottle Posted August 18, 2005 Report Share Posted August 18, 2005 Check output against wind speed, some of them need a gale to produce e decent charge/output rate. Link to comment Share on other sites More sharing options...
dor Posted August 18, 2005 Report Share Posted August 18, 2005 Check output against wind speed, some of them need a gale to produce e decent charge/output rate. quite true, and if it blows slightly faster then it has to shut down - or at least that's what happens to the bigs ones they keep sticking on the Welsh hills. Link to comment Share on other sites More sharing options...
Breals Posted August 18, 2005 Author Report Share Posted August 18, 2005 Rutland 913 spec The Rutland seems to operate over a good range of windspeeds, apparently its quiet too. The DIY kits look a bit involved, but thanks for the links perhaps someone else might have a go... Link to comment Share on other sites More sharing options...
matt Posted August 18, 2005 Report Share Posted August 18, 2005 We've got solar and wind which came with the boat - we have 3x105a, Rutland 913 and 40w solar. If I started again I would look at putting more batteries in and boosting the solar to 200w+, there are some very nice panels around now that work in fairly low light. The windy doesn't seem to contribute much - but we don't use much really, it's only when I recharge the laptop and camera that I drain the current config. In it's current config I can run lights, bilge, water pump, stereo etc. (no TV or fridge) without needing to run the engine, it just tops itself up during the day - even if overcast. Hope this helps. Link to comment Share on other sites More sharing options...
Breals Posted August 20, 2005 Author Report Share Posted August 20, 2005 I had thought that wind was more effective than solar, but after reading the above post I'll have a look at some panels. Cheers. I found a good comparison of wind gens here. Link to comment Share on other sites More sharing options...
