Only ever had pump out loo.... whats the best casssette alternative?
Emja
On 12/06/2018 at 17:33, rgreg said:
I like the Thetford C200, electric flush. It needs plumbing to the water supply if your existing one isn't. There's an even posher Thetford  with a ceramic bowl.
We opted for the C200CS which has electric flush utilising the boat water tank and pump rather than the version with its own reservoir and pump.
3 years on its done the “job” perfectly - very happy with the choice.
We did consider the ceramic version, but were put off by the slightly larger form factor.
On reflection I don’t think the difference in size would have been much of a problem, so might go for that one next time.
▪️We have 3 cassettts - the refresh option which includes a new seat is worth considering.
▪️On line caravan shops were the cheapest at the time.
▪️A quick pre-flush wets the bowl which makes it more slippery?
▪️Proper ELSAN Blue works well for us in prevent any pong - cheaper stuff was not good for us.
▪️A quick post use squirt with Thetford Aqua pink rinse spray seems to be worth while and lubricates the rubber seals.
