LEDs interfere with radio
Top cat
What I don't understand is, why doesn't the feedback loop continue until, in a very short space of time, the amp is driven into full-on hard clipping, closely followed by speakers or amp-chip burning out? Why is the feedback loop self-limiting, and why does it not exist when the aerial is working properly?
  • 2 weeks later...
I've just remembered that back in the days we had a modified sine wave inverter every time the inveter was on you got a buzz from the rear speakers even when the radio was off. As for running the radio with the inverter on forget it. The mains wiring is in its own conduit well separated from the speaker wires.
Which just goes to show just how good those long rear speaker wires are as aerials.
Top Cat
Top Cat
Which just goes to show what a dumb idea they are.
Well when I fitted the rear speaker leads we were running halogen bulbs and didn't wish to listen to the radio with the inverter on. And we had no problems. The buzz was a useful reminder that the inverter was on, and since going full sine wave we have forgotten to turn the inverter off overnight a couple of times, so now we have a warning light.
It was only the combination of LED bulbs and a corroded aerial lead that caused the problem so no I don't think running speaker wires to the back was daft. Fixing the aerial has cured the problem.
The alternative was to buy a second radio with all the issues of installing it especially fitting a second aerial.
Top Cat
Portable radios?
I don't know your set-up, but if you have batteries at the back, a car radio somewhere near the front & speakers near the back, that could mean perhaps 50m of there & bask cabling from batteries to speakers. That's a lot of potential voltage drop. Maybe you have nice fat power feeds to your radio (6-10mm). If you're using car type speakers as well, the power losses are really quite big. Maybe you like listening to music quietly & the problem doesn't show up.
Your boat, your set-up, if it works for you that's all that matters.
I use portables, (dab radio & boombox) flexible & power thrifty, important for me as a live-aboard.
