JV44 Posted November 18, 2011 Report Share Posted November 18, 2011 British Waterways statement on the canal on 17th November. "The canal has been closed to navigation between Crofton Lock 61 and Copse Lock 80 due to lack of adequate water supplies to support boat movement. All of the locks within the closed section will be padlocked to prevent use. We are allowing levels in individual canal pounds to recover slowly. Several sections are very low and will take some time to come back to normal level. This is a long term problem brought about by ground water level being extremely low, in fact it is at the lowest level for 90 years. The reservoir level is also very low and currently has little or no feed to recharge the system. The current stoppage is necessary to recover levels and help protect aquatic life in the canal. British Waterways is currently looking to support the closed section with additional water supply from other sources. The current closure is being reviewed weekly, and with little or no significant rain forecast the current closure may remain in force for some weeks. Craft that are trapped within the closed section are requested to remain where they are, but to adjust mooring ropes to accommodate changes in water levels. Any request for craft movement will be dealt with on an individual basis and will be subject to available water supplies, canal water levels and individual circumstances." Steve Link to comment Share on other sites More sharing options...
