Jacq Posted September 26, 2010 Report Share Posted September 26, 2010 I have a prop that other than RH has some numbers stamped on it. 11325 & 781635. Are these likely to be manufacturers marks or do they indicate pitch & size? Im used to seeing it as : 22 x 19 for example. Cheers. Link to comment Share on other sites More sharing options...
mykaskin Posted September 27, 2010 Report Share Posted September 27, 2010 I have a prop that other than RH has some numbers stamped on it. 11325 & 781635. Are these likely to be manufacturers marks or do they indicate pitch & size? Im used to seeing it as : 22 x 19 for example. Cheers. Similar sort of numbers to the prop that came off my boat. I suspect they are manufactorers part numbers, for example Lister who had seperate numbers for their props. Mike Link to comment Share on other sites More sharing options...
