aread2 Posted September 14, 2010 Report Share Posted September 14, 2010 My Multiplus 12/3000/120 is showing the temparature warning light as soon as it's switched on, in either charger only or in inverter mode. It obviously isn't too hot. Has anybody seen this fault before? Link to comment Share on other sites More sharing options...
Guest Posted September 14, 2010 Report Share Posted September 14, 2010 Why the double post??? If you think nobody has seen the first one, just 'bump' it... Link to comment Share on other sites More sharing options...
aread2 Posted September 14, 2010 Author Report Share Posted September 14, 2010 Why the double post??? If you think nobody has seen the first one, just 'bump' it... I couldn't find it - thought it had gone missing... Link to comment Share on other sites More sharing options...
Guest Posted September 14, 2010 Report Share Posted September 14, 2010 I couldn't find it - thought it had gone missing... Quickest way to find what you've previously posted is click on your profile and then select 'my content'... Good luck in your quest... Link to comment Share on other sites More sharing options...
Arnot Posted September 14, 2010 Report Share Posted September 14, 2010 My Multiplus 12/3000/120 is showing the temparature warning light as soon as it's switched on, in either charger only or in inverter mode. It obviously isn't too hot. Has anybody seen this fault before? You could try disconnecting it from all power for about half an hour and trying again but I think it's telling you it wants a holiday in Holland... Regards Arnot Link to comment Share on other sites More sharing options...
