moodyblue Posted September 27, 2009 Report Share Posted September 27, 2009 (edited) I have a very old Yanmar pmx 8. The gear change into forward is very stiff and can sometimes only be done with 3/4 max revs. The change into reverse is fine, no problems at all. I have removed the control cables and tried the lever direct to the gearbox with the same stiff gear change found.so it cannot be the cables etc. Any ideas !! Edited September 27, 2009 by moodyblue Link to comment Share on other sites More sharing options...
PhilR Posted September 27, 2009 Report Share Posted September 27, 2009 I have a very old Yanmar pmx 8.The gear change into forward is very stiff and can sometimes only be done with 3/4 max revs. The change into reverse is fine, no problems at all. I have removed the control cables and tried the lever direct to the gearbox with the same stiff gear change found.so it cannot be the cables etc. Any ideas !! Have you been trying to change gear with the engine above ¾ max revs? Link to comment Share on other sites More sharing options...
snappy Posted October 19, 2009 Report Share Posted October 19, 2009 Have you been trying to change gear with the engine above ¾ max revs? Hi, That is the only way to get her into gear now. Just will not budge below that. Thanks Dave Link to comment Share on other sites More sharing options...
