Orca Posted March 24, 2008 Report Share Posted March 24, 2008 Just looking at the other recent thread about Boat Electrics on here - I noted that people generally do not run the standard fit Aquamatic independently from an inverter?? I will be plumbing/wiring in (or at least a professional will) mine soon, though as I noted the water heater in such machines is 1300watt and the motor 800watt I was expecting to be able to run the machine autonomously off of an inverter continuously rated at 1600watt. Of course 90% of the time it will be through the shore hook-up, but I wondered if anyone does run thier washer straight from the batteries through an inverter when out cruising?? That is assuming of course the water heater/motor do not run concurrently (they probably do though!?) Sorry to be so long winded - its just my style I guess... Link to comment Share on other sites More sharing options...
denboy Posted March 24, 2008 Report Share Posted March 24, 2008 yes we do candy T10 running off a 1800 watt pure sine inverter works well Link to comment Share on other sites More sharing options...
ITAfloat Posted March 24, 2008 Report Share Posted March 24, 2008 yes we do candy T10 running off a 1800 watt pure sine inverter works well We ran our Candy 10T off a Mastervolt 1500 combi without any probs....we did have a 130A Mastervolt alternator with Pro-Alpha charge regulator too. Washer used to be on almost every day... it did swallow the odd sock mind...greedy machine. Link to comment Share on other sites More sharing options...
Orca Posted March 24, 2008 Author Report Share Posted March 24, 2008 We ran our Candy 10T off a Mastervolt 1500 combi without any probs....we did have a 130A Mastervolt alternator with Pro-Alpha charge regulator too. Washer used to be on almost every day... it did swallow the odd sock mind...greedy machine. Running a 10T off of a 1500 combi is just the kind of thing I wanted to hear - its not your alternator's ability to charge your battery bank that matters, its your inverters ability to AC your washing machine! Many thanks anyway... Link to comment Share on other sites More sharing options...
