henhullpilgrim
Contact Methods
Website URL
http://
Gender
Boat Name
Pilgrim
Boat Location
Henhull
henhullpilgrim's Achievements
Explorer (2/12)
0
Reliance Engineering
henhullpilgrim replied to henhullpilgrim's topic in Boat Building & Maintenance
Thanks for this... I'll see if I can find a copy of the book. -
Not sure Tonka. Thought Norton Canes Boats are the builder at Glascote. Did Reliance precede them perhaps? -
Hi. Does anyone know anything about, or have any experience of this hull builder (Reliance Engineering)? Thanks in advance for any info. Brent
Stern Gland - Packing
Thanks for that guys. Puts my mind at rest. I'll see how it beds in when I return to the water. Cheers. -
I've just replaced the packing in my stern gland and am wondering if it's possible to 'overpack' it. Having replaced the previous three rings of packing with three new rings, the propellor shaft turns by hand (she's out of the water) but only if I turn it using the prop to get some leverage. I can't turn it by twisting the shaft alone in the engine compartment (although grease on the shaft doesn't help). I've never had the need to spin the prop around before (unless removing stuff through the weed-hatch) and so have little experience of knowing how readily a prop should 'spin'. The guy next to me can spin his prop around very readily (almost like a spinning plate) although he admits that he's never re-packed the gland in a number of years. Seems almost as though there's zero resistance in his set up. Is this normal for there to be some resistance initially and that will things settle down once the engine gets going and the packing 'beds-in'? I believe that I've used the correct size (8mm) packing. It went into the packing space (and looked very much like the old stuff for size) but did need some persuasion from the packing plate for each ring. Perhaps I needed the 6.7mm packing - does that small diference really matter? The rings were cut carefully too (at 45 degree angles) and I don't believe they're too long and certainly don't overlap. Perhaps I've over tightened the packing plate? Who knows. Any thoughts out there? Brent
Really Nerdy Webasto Questions
Thanks again gazza for your help. I still can't figure out why the fuel pump won't kick in though. I have power to the main unit and the circulation pump starts readily. Just no life in the fuel pump which actually looks pretty new. From your notes above, I'm not sure that the disconnected pins would affect the fuel pump's performance so what's left to go wrong? Faulty cables to the fuel pump? Faulty fuel pump? Faulty internal circuitry on the main unit? Any one had similar issues? -
Brother-in-law's 'used' Webasto now fitted and in situ. Suspect it may have been a truck/car unit rather than the marine version. However, brother-in-law got it for a song so worth the gamble versus the cost of a new, marine unit. Switch it on and the unit kicks off (after some work on the main power supply cable) - water pump begins and everything appears promising except that the fuel pump does not start... no fuel and no combustion. So, let's check the cabling loom to see if it's a wiring problem. 1. The main timer unit has only three cables (red, brown and black) and not the four shown in the wiring diagram. Where has the other black gone? No sign of it. Does anyone know what the two blacks are for and then we might know if the missing one is crucial for the fuel pump/combustion bit. 2. Let's check the fuel pump cables... both there (blue and brown)... okay, so 3. Let's go back to the six-pin data plug on the main unit. Strip back the sheath and discover: 3a). Pin No. 1 takes a black cable for the timer unit. Present and correct. 3b). Pin No. 2 takes a yellow cable that is not connected to anything. Worrying & puzzling. 3c). Pin No. 3 takes a black cable that is not connected to anything. Worrying & puzzling. Is this the missing timer unit black? If so, why is it not connected? 3d). Pin No. 4 takes a green/white cable that is connected to the relay unit. Present and correct. 3e). Pin No. 5 takes a lilac cable that is not connected to anything. Worrying & puzzling. 3f). Pin No. 6 takes a blue cable that is connected to the fuel pump. Present and correct. Any observations or suggestions? I warned y'all it was just a tad nerdy! Regards Brent
Thanks for the manuals... very helpful. Connector is on its way as we speak.
Thanks. I've sent him an email. Hopefully, this will prove positive.
I'm helping my brother-in-law to fit his Webasto (purchased second hand). It's seems fine but the wiring loom has seen better days. In particular, the connectors (two of them) which are used to connect the loom to the main unit could do to be replaced. One of them suplies the 12v power and the other is used for the glow plug, water pump etc. Does anyone know where they can be purchased easily? Thanks in advance.
Fitting a Webasto fuel pipe
Funnily enough, I did the very same thing myself when fitting on my own boat four years ago. At the time I was told (rightly or wrongly) that all joints had to be compression! Having viewed the Webasto servicing guide on this site, I now realise that I'll face problems taking the unit apart (just as you must have). As a matter of interest, how did you remove the olive on the unit's fuel intake? Regards Brent -
The boat is four years old. Interestingly, the engine fuel feed pipe is on the starboard side (not the port side)... diectly below the filler cap. This caused a problem earlier this month when the engine stopped just 15 minutes after filling up. We suspect the force of new fuel entering the tank had disturbed something that was quickly sucked into the draw-off pipe. We disconected the pipe at the filter and blew air back up the pipe and into the tank. This cleared the blockage. The drain plug on this boat is on the port side. -
I'm helping a friend to fit a Webasto on his Liverpool Boat. Just wondered if anyone had any tips, especially regarding the fuel pipe. The boat's tank does not come witha spare standpipe (as did my Price Fallows shell) to take the supply from and so we plan to tap into the diesel tank, using the Webasto fuel pipe as supplied. This will mean entering the tank's vertical bulkhead, in the engine bay, just under the rear deck. Any tips or cautionary notes appreciated. Any good/bad experiences appreciated. Also, the kit does not come with any sort of fuel filter/water trap. We plan to leave about 4" of clearance from the bottom of the tank to the tip of the draw off but it just seems wierd to not put some sort of device in the line to prevent contamination reaching the in-line fuel pump. Any thoughts or ideas? Many thanks in advance Brent
Liverpool Boats - Fridge Circuits
Thanks Roger... I suspect that this boat may well have been wired by the same work experience youngster as your boat. I have resisted talking down the build quality so far, just in case there were compelling technical reasons for the way the boat had been wired. However, I'm beginning to gravitate towards the conclusion that poor build quality is the only rational explanation. Arghhhh! But thanks... Brent Hi Mike When the fridge is disconnected, the ignition key invokes the usual 'alarm' when turned to the first position. When the key is turned to the 'glow plug' position, the glow plug light does not illuminate and upon turning the key to the starting position, the alarm goes off and the engine fails to turn over. However, there is a clicking noise which appears to be coming from what looks like a relay that feeds the glow plugs. Reconnect the fridge and everything works perfectly. Very puzzling. Regards Brent -
Thanks for your help anyway Rick. Thanks for you help Chris. The fuse in question is 15 amps. However, the cable is quite separate from the main supply cable to the starter motor. It's simply 'added' to the starter motor side of the start battery isolation switch and is routed into the main boat via the engine room bulkhead. We assume it goes to the switch panel but cannot be sure without removing internal wall panels. Puzzling.
