Days Won
36
Posts posted by WotEver
13 minutes ago, Timx said:
I can’t upload anymore photos
Sure you can, you just need to ensure they’re within the site’s size limit. I forget what that is but it’s over a meg which is a pretty huge image.
2 hours ago, matty40s said:
The starter I finally had to replace during lockdown May had a date of 2003 on it. I probably killed it myself by linking it to the domestic bank over the winter whilst on a landline rather than leave it be.
I just had to change the original fitment battery on my 2007 S-Type, but only because the alternator failed; so starter batteries, even on cars, can last an awful long time.
1 hour ago, jenevers said:
How??
They are “stick on”...
Then you can’t.
Unfortunately (and I know you won’t want to hear this) stick-on panels are frequently reported (both here and elsewhere) to have a very short life. I suspect they don’t much care for the very hot steel they’re attached to. Whatever the cause, they never seem to last more than a handful of years.
Just now, Puffling said:
Good to hear your switch to 240v was without any serious power consumption difference.
Not just his. There are numerous threads on here that demonstrate the same.
“The Narrowboat Builders Book” by Graham Booth.
I don’t know when it was last updated, so some of the info might be a little dated now, but this certainly used to be ‘the bible’.
7 minutes ago, ditchcrawler said:
Havent we done this one before...
I thought so, and didn't it turn out to be a non-story?
- 1
6 minutes ago, roland elsdon said:
Then the head fell off the broom.
50 minutes ago, Machpoint005 said:
I agree with the 'include a ruler' plea but in this case we can get some idea of the size from the battery isolator switch nameplate and the cross-head screw that holds it. It is bigger than 2BA, but certainly not 12mm.
Looks like M6 to me.
21 minutes ago, jenevers said:
Tested my 8 solar panels just now. Bad news. 3 show no voltage at all, 2 show 9.3volts , 1 shows 18.7 volts, 1 shows 20 volts and 1 shows 20.5volts. They are only 19 months old. I'm not impressed.
Check the connections on the backs of the panels.
26 minutes ago, mrsmelly said:
I think he may design the Stirling labels that he glues over the words " Made in China " ?
You could be right there.
1 hour ago, OldGoat said:
I just assumed that C.S. designed the box that way....
I don't believe that CS designs anything. At least not personally.
8 hours ago, Chewbacka said:
I think you have mis read the bss.
You are correct that if you choose to use a “pre-made hose assemblies conforming to BS 669” then a bayonet connection must be used, however section 7.9.5 goes on to state that pre-made assemblies are optional and you may “......use suitable nozzles secured by crimped or worm‐drive clips; and,”. There then follows requirements about clip style, size etc.
Therefore bayonet fittings are not required in all cases.
At least that is how I read it.
That would be far more logical so I suspect that you are correct.
As I wrote to the OP, best to check with his examiner and then make his own choice.
51 minutes ago, dave moore said:
I hope that’s decent tape, Mark....I really do.....
It looks like Wilko’s best but of course appearances can be deceptive.
- 1
4 hours ago, Rick Savery said:
That's interesting. At the moment I have a flexible hos with very short pieces of pipe at each end connecting the cooker to the main pipework.
Having taken this off, does this mean that I have to now fit a bayonet fitting to the main pipework and get a hose with a bayonet fitting at one end and the short piece of pipe at the other which connects to the cooker directly ?
Well, reading the BSS regs certainly suggests so as my quote demonstrated. However, I bet loads of boats have their cooker connected via a flex hose without a bayonet fitting. I know WotEver was plumbed without because I changed the cooker and there wasn’t one there. I guess a phone call to your BSS Examiner will clarify what he will and will not accept.
https://www.boatsafetyscheme.org/media/268789/ecp-private-boats-ed3_rev2_apr2015_public_final.pdf
As a friend of mine is wont to say... “Let it develop”. If that screw gains a mate and then another then something’s about to fall off. When it does you’ll know where it came from...
Could well have dropped out of a pocket, yes.
1 hour ago, alias said:
It probably is lack of local capacity. As demand on a base station reaches capacity it will drop the weaker (usually more distant) connections to provide service to stronger/closer connections. That can turn a poor reception area to a no reception area at times of high demand.
You can always fix it yourself
Fed up villagers in Michaelston-y-Fedw install ultrafast broadband https://www.bbc.co.uk/news/uk-wales-south-east-wales-44631791
20 hours ago, Ronaldo47 said:
are bayonet connectors not allowed on boats?
Not only are they permitted but it appears that they are mandated if using a flexible hose to connect a cooker. 7.9.1 reads (in part):
... pre‐made hose assemblies conforming to BS 669 may be used to connect cookers to LPG supply pipework. Such hoses usually have a red stripe running along the length of the hose but may not be marked with BS669.
The connections on such hoses must terminate with self-sealing bayonet connections at the connection points to the LPG supply pipework. The portable appliance connection checks at 7.10 also apply. -
15 minutes ago, Alan de Enfield said:
It is the total number of days in June and September, or April & November, but if you add all 4 together you will need to divide by 2
Gotcha.
Or I could take the days in a year, subtract 5 (or 6) and divide by six...
16 minutes ago, Jen-in-Wellies said:
Multiply by 60 to go from Hz to revs per minute. 2600rpm should give a sharp frequency peak at 43.3Hz, Your microphone should pick this up, but if not, the next peak will be 86.7Hz (double).
You know, I read this and thought to myself “What’s so magical about 60?” It took a while for the penny to drop. Not enough coffee I think
- 1
50 minutes ago, PeterScott said:
Hence this morning lying on the towingpath with a camera waiting for the light and this creature to swim into a good position. This was the best attempt.
You could go and do the same with a sinking tyre now...
- 1
- 2
Hello Bruce, what do you do then?
I’m a taxidermist.
A taxi-what-ist?
A taxidermist.
What the heck is one of those then Bruce?
I... er, I stuff animals.
Oh it’s okay lads, he’s one of us!
2 minutes ago, TheBiscuits said:
Direct link for the lazy
Hey! I resemble that remark!
- 1
1 hour ago, roland elsdon said:
The downside is they are australian models, so to work here you have to stand on your head ( or hold them upside down) and shout strewth when you finally get a connection.
And change your name by deed poll to Bruce?
- 1
20 minutes ago, matty40s said:
Tommorow is the last outdoor painting day of the year....after 10am......depending on local fog clearance....(South of Manchester)......and not after 3pm .
Yup. I’m hoping the pressure washer arrives early...
Yorkshire Gravel Barges - Happier days
in General Boating
What does that ‘share’ button do?
