WotEver
Patron
Posts posted by WotEver
  1. 3 minutes ago, tearoomtom said:
    Please read the original question and reply accordingly. I do not want to run my boat on kerosene but my Weabasto heater.
    Yes, but other folk have asked if they could. Anyway, your question was answered in the first couple of replies.
  2. 3 minutes ago, Higgs said:
    So - I can't now have a mooring , without a licence. These licence terms and conditions are very well hidden.
    What license terms & conditions? We’re discussing your contractual obligations to the Marina.
  3. 1 minute ago, Higgs said:
    Please have CRT make that a stipulation, the next time they update their own terms and conditions. They won't, they can't.
    Whatever are you talking about now? We've been discussing your contractual obligations with the marina - that has nothing to do with CRT.
    Just now, Higgs said:
    So basically - it has no purpose in the marina. That is what you're saying.
    Of course it serves a purpose.  You cannot have a mooring without one.
  4. 1 minute ago, Higgs said:
    I do. Not to the licence agreement I have with CRT
    Unfortunately for your argument, the two cannot be separated.
    You base that on a statutory requirement?
    How many more times?  It's a contractual requirement.
  5. Just now, Higgs said:
    This is your assessment of what a licence is? A tool to gain access to a marina?
    In the circumstances described by you, yes, that's all it is. The marina contract states that you must have a license, therefore without one you cannot have a mooring in that marina.  It's really very simple.
  6. 16 minutes ago, Higgs said:
    Make up your mind. Am I supposed to be buying a licence for the benefit of the marina, or, to give me entitlement to use the canal .
    Neither.  You are buying a license in order to comply with your contractual obligations with the marina.  By happy coincidence that license will also permit you to use CRT's waters.  Of course, you're under no obligation to do so but you can if you wish.
  7. Just now, Higgs said:
    That wouldn't solve the issue.
    But it does.  Because if you breach those terms (by not having a license) then you won't have a mooring.
    There's no law that states I have to pay the farmer the rent for my business premises but if I didn't then I wouldn't have any business premises.  It's a very simple contract, just like the one you have with the marina.
  8. 39 minutes ago, Higgs said:
    The 'ownership' of water is based on the rights to the land, over which the water sits.
    I don’t believe that is correct. If CaRT drained the canal I think you’d find all the boats in the marina sitting on the mud.
  9. 11 hours ago, sailor0500 said:
    https://airlinktransformers.com/product/enclosed-isolating-industrial-transformer-wm2257
    Just been looking at the airlink site and think this may fit my requirements, possibly with a soft start fitted as others have suggested. I would appreciate any constructive comments/ observations. Thanks Mike.
    Not waterproof, so it can't sit outside and it's metal, so the case must be earthed - a big problem in itself.
  10. 24 minutes ago, Pastis said:
    And so for the position of the MPPT, in parallel of the inverter (using the same battery fuse 4)?
    The fuse is to protect the wiring and it is a dead cert that the inverter's fuse will be way too big to protect the cable coming from the MPPT, so that will require its own fuse. You can connect the MPPT cables directly to the batteries (via that fuse, but keep it outside of the battery box), or to the battery side of the isolation switch, or if it's more convenient, to the DC connections on the Combi.  Electrically they're all the same, and any of them will comply with the BSS.
    30 minutes ago, Pastis said:
    I read somewhere that a there should be somewhere a charge controller, wired to both the alternator and the inverter "battery terminals" ?
    Certainly not a 'requirement', and they make the alternator work a lot harder than it's probably designed to do. Nevertheless it's an option.  What alternator do you have?
  11. 1 hour ago, Pastis said:
    Eventually the shoreline was also going to the inverter which has a charge mode (+inverter mode), so first question is : could we wire the generator to the AC input of the inverter to replace the shoreline charge system ?
    Yes. :)
    Are you mistaking the "inverter input" for the battery charger input ?
    I think you missed...
    So it's a Combi.
  12. 2 minutes ago, Soozie said:
    Will I have to get it welded if its a hole?
    Oh, if only anything in the BSS were so cut and dried... Certainly, welding it would be perfect. Putting a nut and bolt through it along with sealant would be satisfactory according to Rob at the BSS, but some examiners will argue the point. If it's above the height of the gas bottles and any other connections then it doesn't matter anyway, but again, some inspectors might argue the point.
    5 minutes ago, Soozie said:
    So in terms of BSS. im not using gas, theres no gas appliances on the boat, the two fitter points on the gas pipes the previous owner installed have been capped, will it go through like this or do I need to do something else?
    I see no reason why it shouldn't pass.  It is effectively a gas-free boat.
    It would still be a good idea to find something to plug that pipe, even if it's a wedge of wood, simply to prevent any spiders from setting up camp.
