nb Innisfree
Days Won
6
Posts posted by nb Innisfree
BBC News - Major incident declared over Shropshire canal 'sinkhole' - BBC News
https://www.bbc.co.uk/news/articles/c2lvq0yk9dko?app-referrer=push-notification -
25 minutes ago, MtB said:
In a new house installation that's an instant water regs fail!
Cross contamination with heat is not only not nice for cold drinks but presents a legionella contamination risk.
I've been struggling with a similar prob in our house b/room basin, mains and cyl dhw (from a shower pump) sharing t/static mixer tap & non return valve back leaking. Decided to run pumped cold supply to tap & mains to dedicated cold tap.
Mains & low pressure tank/cyl just don't like each other despite NRVs.
This was my solution on Innisfree
2
2 hours ago, NB Thistle said:
In the fire service we were taught 1l of liquid water expands to 1800l of water vapour. That's how water puts out a fire best, you put just enough on to fully vaporise (removes more heat than just cooling) and displace the oxygen from around the combustion. The Swedes did a study and found you can extinguish an average sized living room completely involved in fire with 13l of water - correctly applied. Most people though just drown a fire!
We were just starting on that method when I retired from FS and iin '02, but faced with a real goer & nowhere to shelter from intense heat while using that method I still preferred to blat it back with high pressure fog from a hose reel!
Old fashioned has been prob 😂
When I fitted out Innisfree in 2005 I fitted a 3kva 24v Victron, recommendation from Victron was 4/6 x 110ah batts, eventually ended up with 8 x 120 AGMs, boat had all mod cons, full size auto w/m etc, worked flawlessly.
Nowadays with LFP it would be even better.
1 hour ago, Tony Brooks said:
I would love to see you store that lot in the gas locker on our boat, mind you, mine had a proper gas locker, not some oversized "waste" space in the bow, so not everyone does, just some people.
I used to keep genny petrol in a gas locker, but it was a spare locker specced by me at hull build, beginners naive concern about bottled gas supplies on the cut, glad I did though.
Lots of assumptions are made, I recall a boater trying to figure out his electrical probs, he had removed his batt banks & stated that he could deffo eliminate those on the basis that they were good batts & were fully charged (after all he'd run his engine at least 2 hrs 🙄) When I put a multimeter on them it recorded 11.5v, he refused to admit they were nearly discharged even suggesting my meter was faulty! I politely made my excuses & left.
You can lead a horse to the water etc...
20v max = marketing BS (18v really)
I use Dewalt, had drill for years and it's been abused but refuses to die, (same for me!) some Ryobi and unbranded stuff on converters so I can use Dewalt batts.
3 hours ago, MtB said:
Must have been something wrong with it then.
Mine ran so quietly that people walking past the boat didn't realise is was running.
It was quiet, but "silent"?
İ found it noisier than expected
Quote:
"The noise level of the origin WhisperGen, a micro-combined heat and power (MCHP) generator driven by a Stirling engine, was rated at 44 dBA at 7 meters.For context:- A range of 50-60 dBA at a specified distance is generally considered "quiet" for a generator.
- The original design was intended to be "unobtrusive" due to its continuous external combustion process, which avoids the noise and vibrations of an internal combustion engine.
- Despite this, in domestic applications, the noise was a subjective issue for some users, leading to recommendations for installation in utility rooms or with acoustic enclosures"
Only time I saw a Whispergen in the flesh & running was on a trade stand at Crick boat show, advertised as "silent running" it was anything but.
Bloke once tried to to flog me a petrol genny that was "super silent sor" 😊
Whispergen:
Inefficient electric genny but good heat genny.
Quote:
"Sounds brilliant until you look at what it actually produces - a measly 750W of DC power (ie about the same as a 50amp alternator!) But it also produces a hell of a lot of heat - 6000W!! - which presumably has to be got rid of somehow unless you need it for heating the boat" -
With Innisfree I used to open a hot tap & pump air in with a small compressor then open the PRV & air pressure would push water overboard out of calorifier at that point
5 hours ago, system 4-50 said:
They certainly started early in those days!
12 hours ago, Pinkatpole said:
The Tile Experience appear to do 10cm square white tiles
When I started work as a 15hr old apprentice wall & floor tiler in 1962, 4.25." tiles were the latest fashion, handy as 4.25" on the diagonal = 6", allowed for some 'trendy' layouts.
Soon after blue vein tiles made an appearance, heady stuff!
Re prop makers: We had various size calcs from a few suppliers & reading various sources decided on Crowthers, the bloke there (can't recall his name) didn't do any calcs, based on boat length & draught + engine & prop dia he guessed pitch & blade area, & guess what? He was spot on! A real beauty, which made all the others wrong 🤔
Armed with knowledge
Maybe Tesla has the answer
https://evchargingstations.com/chargingnews/teslas-new-nickel-based-battery-cells-90-soc/
Or maybe not..
- Popular Post
- Popular Post
Everyone please remember, don't get the impression that portable fire extinguishers are to be used for firefighting, they are simply a means of assisting people to escape a fire situation.
5
I used to be undecided but now I'm not so sure🙄
Smelly, try hitting it with your club.
2
Where we live Vodafone is the only reliable option though it does give us 1st class service with unlimited data etc + 2 x half price phone sims with 20 gb data each, but all the same roll on cheap satellite.
5 minutes ago, Ronaldo47 said:
My understanding, from university-level geology text books rather than the Internet, is that changes that can persist for a few centuries, can happen over significantly shorter time scales than "thousands of years".
When the Ronans invaded britain around two thousand years ago, it was warm enough to support grape vine cultivation, and evidence from pollen grains in dateable sediments in lake beds, indicates the then presence of plants that would only thrive in a warmer climate than today's.
In the Viking era of about a thousand years ago, the northern hemisphere was still a few degrees warmer than today. Greenland was sufficiently green with vegetation to be able to support Viking agricultural communities for several centuries until climate change made it too cool for agriculture to be viable.
This was followed by the 'little ice age' of the 16th to early 19th centuries, where the climate of Northern Europe was a few degrees colder than today, when rivers like the Thames would regularly freeze over in winter.
I am not sure what reference datum is used as the "pre-industrial age" that is often referred to when defining the global rise in temperature (which can only be estimated, as accurate thermometers have only existed for a couple of centuries), but would not be surprised if it was at the tail end of the 'little ice age'. A different picture would no doubt result if the Viking era temperature were used as the pre-industrial era base line.
I am not denying that man-made emissions, and possibly just as significant, man's destruction of forests that capture carbon, have an effect, but would be surprised if it were the only cause.
These things can only ever be a matter of opinion, as we are never going to know the real cause, or causes, for certain, as we cannot suddenly stop producing man-made emissions to see if things improve.
And yet we are still in the last/present ice age!
We can only guess, as always, what the future holds for us.
I remember responding to a TV D radio plea for all off duty firefighters to report for duty, I finished up as a crew of 4 standing by to protect a large conurbation.
A part time leading fireman was in charge of us & like Capt Mainwaring he was catapulted from obscurity to a position of power & importance (or so he thought!) sat expansively behind the Station Offices desk 🤣🤣🤣
Happy days.
Carbon Monoxide Scare
in New to Boating?
Our alarm registered a low level of CO, turned out to be smoke from stove chimney blown by the wind & curling down into a mushroom vent, only when wind was in a specific direction & speed + vent was a specific distance from chimney, took me ages watching over a few weeks to pin it down, cured by a fitting a long chimney.
