Days Won
2
Posts posted by bigcol
Hi Mike
just to say have spoken to Ed, and he’s coming tomorrow to sort out the wiring re beta alternator.
thank you very much
col
Thankyou Mike
will ring him
col
Does anyone know of a electrician I’m the MK area that can wire the domestic 24v alternator in, we have instructions from beta, and modified leads.
many thanks
col
copy of message sent to our freind Alan,
realising how lame it sounds
the planar people can instal this week if I let them know today
and it’s got cold now, I’m now trying to get the missis to cuddle up to keep warm lol
she said get the sodding new heater lol
Hi Alan
the heater problem has still not gone away, I’ve got a spare old unit minus the blower chamber as I’ve wrecked that trying to get to the fan motor inside.
so I’ve rang up a agent that I’ve used for sometimes, butlers and sputechnik and he can get it collected but the min it would be is a 100 pound then of course more labour and maybe parts,but this might take up to 4 weeks due to staffing.
or I’ve been offered a brand new planar 8kw including installation for just under 900 pounds
and don’t know what to do, or indeed why I’m passing this problem to you lol
the planar is a planar direct from them, not a Chinese copy.
so what do you think, I’ve messed about with it for a time, wish I could get a local engineer to fathom it out.
ive already fallen down the engine room twice lol
tiring but being tight but still sensible just confused .com it what’s the right desision
lol
As per heading.
just to say wildest dream moved for thr first time ever ever today, and thought posting it,
and receiving comments on how long,and why so many times using the BT
thought folks would like to mention the BT
LOL
ps it’s not that some folks helped this boat burst into life
- 1
we’ve still got heat!!!!
Just to say, a big Thankyou to all who gave me the guidance, and collective knowledge of this forum.
Including the fault finding manual.
- 2
- 2
Top of the range these,
forget about the other snap on crap lol
col
53 minutes ago, Alan de Enfield said:
Well done for sorting it out.
One of the benefits of carrying spares, you can just swap out until it works.
That’s exactly what I done the end!
thankyou all!! I’m so relieved!
heat!!!!!
Okay,
ta da!!!!! I have heating!!
it was the blower assembly, just changed it over.
im so gobsmacked, so chuffedThankyou all
col
Happy happy happy
- 1
- 2
OkaY
glow plug works, seen it red and works on and off unit.
tried all ways to get diagnostics to work, done as per Tony’s photo just can’t get it to work???
knowing that the glow plug works, tested pump all okay.
dismantled spare one, too fan motor out, just plug in the spare one and the difference , fan run big time like normal
i have the heater in bits I’m sure it’s fan motor
The 24v unit although 2012 purchased, it was never used until under 2 years ago,since instalation 2 years ago it has behaved brilliantly and has never let us down,
till 2 days ago. the other spare unit is also 24v.
i haven’t been down the bilge room anymore to day, apart to doing tests as above, due to feeling unwell, but fingers crossed I can go down again ist thing tomorrow suss
out these jump wires and get the diagnostics working.
ps I was hopping the fault to be the glow plug, as that would be the easiest and the less expensive. Which is why it’s so annoying that a simple test, suggests that I’m doing this wrong!!!
thank you all for your support
col
this photo is the glow pin I have
1 hour ago, Mike the Boilerman said:
Ok one step at a time. Do you have a digital multimeter, with a known-good battery in it?
Yes I do,
There are 2 wires that join together to a washer that gos over the threaded tip, with a small nut to tighten.
To the top pin, that holds the nut and wire on when in the machine
not the bottom that screws into the heater
okay
both glow pugs have been tested by
donig a contiuety test on both that passed thatA. Put a positive wire direct from 24v to the tip of the plug
B putting the neutral direct from 24v to the body on the plug
both times nothing
so to assume I’m doing the rest wrong?
or b0th plugs are knackered
I haven’t got a clue re testing resistance
thankyou Tony and Mike
Well yesterday I tested the glow plug, in fact I took another out of a old unit that I bought of EBAY.
put both in nothing. And the glow plug is the 1st thing tat is triggered in the start up sequence, which is why I started with it.
Alan reminded me about the dianostic switch so played with that,really nothing.
later on got the trouble shooting manual from Alan, and started reading, and reached diagnostics, and this is the first thing I came accross
see photo.
so putting a jumper accross, does the mean a wire?
col
Alan. I’ve messaged you again
11 minutes ago, Mike the Boilerman said:
Presumably your battery bank has a decent ammeter, a BMV702 perhaps, given it is 24v.
What does the ammeter read before starting the Eber, and what does it read during this 20 second spin-up?
I will test this when next down in engine rm
thanks yet another good sugestion
Thankyou Mike
Hi Alan
not as yet,
im waiting for them so I either work out how to work the diagnostic button,
seems as though I’m just relying on forum members,and to try to read through of testing the glow plug
but if the direct battery test is correct, then it’s the glow plug.
24v positive wire direct to the glow plugs tip
fingers crossed but it be great if the diagnostic test would work and confirm that it’s a glow plug fault.
thanks all
Hi Alan. I’ve sent you a message m8ty
colin ?
Okay
1st testclamped positive cable to tip of glow pug direct to battery. NOTHING!
2nd test
with the glow plug back in unit,
started up fan spins for 20 seconds. NOTHING MORE THEN STOPS
3RD TEST
started up with diagnostics side on, fan started stoped and NOTHING, re the thermostat diagnostic nothing beeps or lights.
we tried this twice
tried a third time lights continually flashed till turn off.
Alan have you got the link re manual online, I’ve tried but didn’t get far
col
35 minutes ago, Alan de Enfield said:I’ve got no chance of ever understand this drawing ever!!!
in General Boating
