Hi Everyone, A couple of months back I requested info on the best way of heating a calorifier using a vintage engine, specifically a JP2. That is now sorted and working well, so I'd like to say thanks to those who replied and helped. And so to the next problem, or two actually.
Number one- when I built my engine 20 years ago, I found that the cast iron, water cooled silencer which sits on the engine block had cracks in the water jacket and leaked. Welding only partly soved the problem, so I had a go with JB Weld epoxy filler. This did the trick, and I've had no problem for a long time. However, the iron has rusted over the years, and foced some of the JB Weld away from the crack, and it now leaks slightly again. I am tempted to clean it up , and have another go with JB Weld, because 20 years is pretty good I reckon, unless someone can recommend a more modern, and perhaps better, alternative. I have to say that the only access to the cracks is from the outside.
Problen Number two-- I can't get the cylinder heads off! I've tried levering, tapping with a lump hammer and they won't move. In the book it says"use the engine compression to shift them", but its a hand start engine, and the starting mechanism is fastened to the top of the silencer, which is on my kitchen floor at the moment ( see problem one, above).
I tried feeding some clothes line through the injector hole to sit on top of the piston, and then turn the engine using the flywheel, to try to lift the heads, but the combustion chambers in the heads are small, and won't allow the clothes line in. Does anyone have any bright ideas?
