Posts posted by nb blackbeauty
It's getting dearer the further south you go, left Birmingham over month ago paid 70 p Frampton on the sharpness 74p out side Bath fuel boat 78p now in Reading fuel boat 88p. Although no split payed.
Thanks for your info on fuel.stopped the fuel boat out of boatyard wharf 74p no split.
Any fuel boats on the K&A were at Bath at moment going all the way to Reading or cheap fuel along the way.
Just had my fuel polished and refilled to to top so that will help.
Thanks for quick response will refill filter with fresh diesel.
Just about to change fuel filter on my barrus shire 45 engine. Do I need to prime the the filter or will it self prime when I start the engine.
Could be worse you could be moored at Minworth on the Birmingham and Fazeley canal when the wind is blowing from the sewage works.
Many thanks for your input think I Will Go for the smaller of the two it is half the price and it's got to be better than the one have. Have always struggled with seeing in tunnels and yes I always put cabin lights on have been on the cut 18 years it must be my eyes it takes me a quarter of the way in those tunnels to feel comfortable seeing anything.
I need to change my tunnel light on my boat which is 68 feet from the old brass car head light not very good at seeing anything. Have been looking at bedazzled and 2 stand out 1 has 9 LEDs 27w 30 degree the other has 14 LEDs 42w 60 degree what do people think is the best choice. I know it has to be angled to side and roof and my local tunnels are Netherton and Wast hill tunnels both long with would the 14 LEDs be to Bright for on coming boats.
Thanks for this info -really useful! We are planning to go downstream to Bristol next May from Sharpness.
Overnighted in the grazebrook arm Monday night it was very quiet due probably to the high winds and late in season. But must say it was a lovely location and we were in a sheltered spot.
We're heading to the Stourbridge rally and thinking of overnighting above Park Head locks as we've not been up there before, and as a change from Merry Hell. Is it safe to moor there? Any local knowledge much appreciated.
18 months ago I had to replace the diaphragm in the governor on my Mercedes engine (om636)which had perished as they seem to be made of leather. Took old one out replaced new one started engine easy enough but when I went to stop engine the stop lever would not stop engine. This was before the cable was attached and no amount of adjusting the stop bolt will kill the engine.The only way at moment to stop engine is to push the control rod at the other end of governor - this has been fine so far for me with no cable ( I got used to it, as even manually didn't stop it) but the new owners of the boat want the cable/lever sorted before they collect. It's proving trickier to solve than I thought - any ideas please?
John
All sorted now - Rose's came good in the end. Thanks for your help tho.
Hi All
Have a friend on the North Oxford near Roses boats who has a broken lift pump on a SR2 Lister.
Can anyone let me know his nearest suppler, he has only a bike and Roses boats cant help.
Ta John
What exactly is the name of the 'high temperature goo' you used? I have used the red sticky 'Plumba-flue' or some such name at the top end of the flue, but it's no good at stove level, where I've had to stick to fire cement and stove rope.
Mac
Hi Churchward
Did the same job myself the week before including changing the fire with another (Morso Squirrel) but I was lucky that chimney collar was serviceable after replacing the flue pipe. The sealant you speak about is Plumba Flue I have used this to good effect. Not only sealing joints on the outside of the fire but when the screws holding the glass in the door snapped I used it to keep the glass in and this has stayed in place for over 3 years of constant use being a livaboard and is now a spares replacement for the new fire.
John
Looks like common duck having bad hair day
Thanks both have now conected, will fill and try out in a month or two.
John
Am I right in thinking that all of the connection are done to the rads, back boiler etc and you just need to connect to the header tank?
If so, connect the bottom (outlet) to a local low point in the system. The 'overflow' to a local high point.
Under normal operation the header tank will just sit there gently raising/lower its level to compensate for the expansion/contraction of the water in the system.
Is the header tank open to atmosphere or is the system pressurised?
Hi Proper Job
Yes makes good sense to me to have outlet to low point and overflow to high point.
But seem to remember that overflow pipe went outside through hull.
Could this have been wrong in the first place has it came with the boat and I have had the boat 8 years.
The pipes and rads only ever got hot/warm 1/2 way down the boat depending on how high fire is.
The fire is a new morso squirrel 22 mm pipes, fire at front, header tank 1 gallon capacity open the atmosphere at back of boat and the boat is 60 feet.
Hi All
Help Please,Just replaced central heating system which I removed 18 months ago doing fitout on side of boat thinking i could do without it WRONG.
Now all I saved were radiators and header tank,
I have now replaced all radiators and pipe work to back of boat were header tank is.
Now I forget how it joins up.
Header tank has out let at bottem and over flow at top.
Thanks
John
That was excellent cheers
Your not a real boater till jumping onto a freshly cut toepath to find what sould be terra firma has been camouflage with grass cuttings and the edge is a foot further back
Daz... moving his boat... this we've gotta see! See you next weekend methinks
No... he is not coming on his own boat silly. That moves even less than Nine of Hearts boat does.
John, not spotted you on here before, where you been lurking?
A little jawing in the POW is allowed surely.. Just a little..?
Hi Bagpuss.
Been reading canal forum for ages but not scrolled down to the Virtual pub, seems i have been missing all the fun.
Meeting up down at the Vale next weekend come along if you can should be about 5 other boats even Daz is coming.
Planning for living costs on a canal boat.
in General Boating
Posted · Edited by nb blackbeauty
Depends where you are going to live. Down south expensive up north cheaper. I live in the Midlands which is reasonable.
