After having a leaking fuel pump for a couple fo years it was finally time for a re-ferb. Having removed the pump and had it reconditioned at a reputable local pump center along with new injectors. I've installed the new pump, fuel filter, blead system, good flow from lift pump and both bleed values. Engine will start every time but die after a couple of seconds, I can repeat this process as long as I like and at any throttle but it will always cut out straight away almost like the solinoid was cutting out (if it had one).
Is there something im missing? Before I go to the pump supplier. (I really dont want to remove the pump again)
Im also reluctant to start tampering with the pump to much like breaking workshop tamper seals, will invalid any warranty.
Hopefully its something stupid and simple I've missed.
Thanks
Marc
