Thanks Tony.
I'm asking for my own boat...
I've a BMC 1.8 with a temp indication not working.
The sender resistance is about 1000 ohms even when the housing is too hot to touch.
If I pull off the wire at the sender and touch it to gnd, the needle on the dash goes full deflection so I think the gauge and wiring is ok and So I think I need a new sender.
Mikexx said above that it's a 5/8" 18tpi UNF thread and I assume it's european standard, but I'm not sure if the thread is 2A or 3A or if it matters.
On the vdo website I found this one... https://vdo-webshop.nl/en/temperature-sensors/410-vdo-coolant-temperature-sender-120c-5-8-18-unf-3a-4103590689641.html
Then also list a 2A version.
I think 2A/3A is to do with the tightness of the fit, but I don't know which one I need for a BMC1.8/Thornycroft 108??
Rory
