Hopefully this reply will go to rusty69 and administrator - When measuring the starter battery volts, i disconnected all other wiring and put a 300ohm resistive load across it expecting to see a serious drop in volts..not so.and the battery isolator connections appear solid..... I have checked the connections for security but not the voltage measurements - Thanks for that - I would hope that with so little use any hardware would not fail - However !! The voltage reading on the control console indicated 12.2 after the glowplug heating light goes out. NOTE - the gauges in the console have some condensation inside - surely not a wiring problem?
What is it that makes the clicking / claking noise when it first failed - sound like a relay contact.??
Can you recommend any web site for information on the correct wiring for the battery charging, connections to the alternator and starter motor - I have some info but dont fully comprehend. I am back at the marina next weekend and will try all recommendations
thanks
