Hello - is there anyone out there who can help please:
The boat is a Water Bug from Springer Engr. The engine is a 3 cyl Kubota. All was well - out at the weekends. Two weeks ago went to run up the engine and switched to heater(plugs) on, counted to 15 and switched to start- and nothing!
Symptoms: Fully charged battery, master switch OK with negligeable voltage drop. All wires and cables checked and tightened, cleaned. On first position of ignition switch buzzer sounds but plug relay does not pull in. Tested relay coil - with 12v operates fine. BUT only 2.5v across terminals 85 and 86! The wiring to this goes to back of alternator then up to ignition switch.
Ignition switch voltage drop across terminals is less than 0.3v.
Engine will not turn over when switch is turned to Start and No sound from Solenoid, panel lights dim. Battery voltage drops but stays above 10.75 volts on this load.
Had small amount of smoke issuing from no.2 plug area!
There is only one relay - for the plug heat. There are no fuses in any of the primary circuits, only in the leisure ccts (second battery not connected at this time).
Engine Stop is mechanical and fully off.
So two problems or are they connected? Grateful for any help as have now spent two weekends getting nowhere.
Tony
