Days Won
Posts posted by LEO
Hi,
Good set of gauges, not many mentions of the hour meter being useful though, like you I have one.
Hi, a 'relly' had 2 pugs, one seemed to pant a lot with it's tongue hanging out and licking everything, it had a flat face and both these actions indicated a shortage of air due to the flat face, Both dogs needed careful cleaning of the folds of skin on their faces as these areas became 'grubby'. One had to go to the vet to have it's anal gland draining on a regular basis. both were male dogs and one was prone to over eating, mainly treats from over indulgent owners and as a result it became fat.
Overall nice dogs, but hopelessly over and interbred to achieve the flat faces which causes the breathing problems. I like small dogs, mainly Jack Russells and Westies.
Thanks for the info.
Some years ago, I visited the basin and saw this ironwork, the boat it belonged to is long gone, I wonder if it is still there?, It's worth having a look at the basin as I think a Building still remains and the chalk stream still flows strongly. It's a nice walk into the village (it's a large one) and near the clock tower look for the Heron Path, a pleasant walk along this past the old school buildings will link up with the stream, fences indicate it was adopted as a canal feeder collecting water from an area known as Wendover Springs. It has flowed strongly and steadily for 200 years as it drains a big area and does not suffer from too much water extraction. At the end of the path is a large pond, the sluice control iron work copies that found on the Grand Union.
Well worth a visit.
Good pictures, sorry to read of the problem, having a look at the scope of the rust I would check the electrical connections on the boat to see if there are any problems causing the widespread rust.
Excellent video and replies, with some good photos (thanks), the Wendover gatherings were good and raised lots of money for restoration, but they were hard work, usually the weather was kind, but one year was a washout!, then the field was sold and no more events, one was held at Apsley but it was not the same...my boat is a 'dot' in a couple of the pics, will the canal reach Wendover? hope so. I think the first gathering was the mid eighties, when a group of D&DBC boaters reached Tringford one Easter.
If you look carefully, the iron prow of a long lost boat is visible in the basin at Wendover, the railway 'twix Wendover station and Halton Camp carried coal. It is also worth reading 'Water from Wendover', which details the very constant flow of water from springs just outside the village, a walk up the Heron Path, starting near the clock tower along side this stream is good.
56 minutes ago, Athy said:
You make an interesting point, Tony. When I start the engine from cold, I generally gradually increase the revs until they reach maximum, then run it at full revs for 20 or 30 seconds, thinking that this will help get it to working temperature more quickly. Am I harming the engine by doing this? It's a Gardner 2LW, if that makes any difference.
I have a similar engine (2LW), I usually start it after turning it over a few times with the decompression lever open, it uses a thick grade of oil and this cold weather ...........also press the button for cold starts in the winter- that helps.
I do cringe when I hear people rev any engine hard on starting.
I did see a Gardner 6L2 with a small tray below the air filter which you could fill with meths to warm things for Cold Starting......
But Gardner 112695 always starts first touch of the button.
How things have changed, I have not had a 'local' for years, but when I did we all used to have our own tankard at the pub, usually in the Landlord's hand as you walked in ready to be filled. Guess those days are gone forever.
Redshaw's do a nice brass unit, but the arrangement on my boat works well. with a brass speed wheel, a long metal rod and parts from a car jack - the sort which used a long screwed rod.......
16 hours ago, David Mack said:
A Gardner 2LW is a 24hp engine. Whether it is capable of doing the Ribble Link depends far more on the gearbox ratio and propeller size of the boat in which it is fitted, and the prop diameter may in turn be constrained by hull draught.
The Ribble Link passage can involve operating at higher engine power than is normal for narrow boats for an extended period. Boaters with higher powered engines than a 2LW have found their performance limited by inadequate engine cooling (undersized skin tank), rather than the available engine power.
I thought it was rated at 28 HP...............
Another vote for Oxon, did a good job on Albion Mills, it was some years ago and they may be busy now or Chris is doing his 'Roses & Castles', more recently they did a good job on a tug style called Cypress.Sounds as if you are close by and might be able to call in....
5 minutes ago, Tony Brooks said:
Apart from the fact that they are VOLTMETERS I would not trust their accuracy unless compared with readings from a calibrated multimeter. However, they are, in my view, fine for a quick glance to say get a VERY ROUGH idea about the degree of battery charge, or perhaps faults on the circuit it is connected to.
Agree...thanks.
Interesting comments, with regards to ammeters, I find the digital ones which plug into Lighter sockets useful, in cars and on the boat, any views on them?.
Hi,
Drip Feed oil burners - Kabola, Refleks have become the biggest ( I almost typed boring) problem after leaves in the cut, or my boat goes much slower after Oct 00,01 am, I have one, a Kabola OD4, they are good stoves. Fuel sitting in the pipes all summer, goes off, the small bore copper 'twix' carb and burner pipe gets blocked, I had all these problems with my 20 year old unit, and the burner pot developed a pin-prick hole. I took it home, re-built it, cost about £300.......now like new it lights first time, (took me 17 years to achieve this), burns perfectly. I have managed a low flame setting, for the unit and can get it to run without the pump..........the big problem with these units is one carb. seems to fit all - some units, like mine really only need setting 1 to 2.5, anything over that and the flame is too big. it boils...........have fun, until next year. Oh! and the units like to run constantly............ short term burns coke them up.
15 hours ago, David Schweizer said:
An interesting film which brought back quite a few childhood meories. As a small matter of interest the hideous office block built opposite Harvey Taylor's old sheds was built on the site of my Uncle's Motor Cycle sales and servicing garage, which was purcashed by compulsory order for the road widening scheme.
Small world, I used to buy spares for my motorcycle from that store 1964/65, It was quite a big outlet, across Walton Street. Some of the canal buildings were taken up by Mick Riley who also dealt in Motor bikes.
I thought you would like this. Another interesting point cropped up on UTUBE...I would have thought the Ship inn was built around the same time as the canal, but a local historian bought an old Will off Ebay, this dealt with the disposal of a persons estate, the will was dated 1737 and made specific mention of the Ship inn.
I thought one section of this film might interest some members, it features Aylesbury in 1966. At 2.50 there is a small section showing the covered bay and storage building fronting Walton Street. I seem to recall a crane adjoining this building, but that has gone.
In 1964 I used to spend lunchtimes eating rolls purchased from Jackson's bakery nearby, sitting by this warehouse and recall narrowboats being converted, I see there is a Dolphin cruiser for sale at £750.
The film is interesting as a fair few of the redeveloped buildings in the town have had a short life of perhaps 20/25 years before being knocked down and the site re-developed for a second time .
The warehouse was demolished and Kingfisher House replaced it, there is a a glut of offices in the town now and Kingfisher House was converted to flats.
Shame the proposal to continue the canal to connect with the Thames at Dorchester was never implemented.
Thanks for the tips (I and M), will take into account, I found gas lockers on Tug decks produce some amazing ways of complying with BSS inspections (albeit for the short term), and the small bottles seemed the safest option. 13 Kg bottles are heavy too lift and re-filling seemed a tricky option.
Hi,
Looks as though I will have to modify storage arrangements on my boat which has a tug deck. The difference in height between small bottles and the 6Kg ones is 155mm. I will probably remove the locker lid, raise the upstands as necessary to accommodate the new bottles and refit the lid and hinges, Will involve a small amount of welding, but would not affect the lines on the tug deck too much....
1 hour ago, Ogwr said:
I recall an article in W,W, concerning Alan Picken and an illustration or picture? of this scene was used
Thanks, do you recall how long ago?...........
Thanks for all the input, I did wonder if it was somewhere down there, it would seem artistic licence has taken over, I see it is just off the A40, I might 'buzz' down for a look. Wonder if those 2 boats did end up there?.
Once again, thanks....
Mike.
15 minutes ago, Cheese said:
This article http://gregoryeditions.com/a_ingham_bio.htm indicates that all the artist's paintings are "real places and .... hopefully identifiable".
Thanks, very useful.........explains his knowledge of boats....
Thanks, Met you some years ago when yo
ur boat was being blacked at Cowroast.............hope all well...
Anyone remember this - a good Bank Holiday Do.
in General Boating
Had this hanging on my Gardener's Lavatory Wall since 1997...................memories of a good weekend, I recall it raised about £70K towards restoration. Weather was usually good, good gathering and some boaters visited the Rally at Braunston (pre Crick Days?) on the Saturday. Shame it stopped.
Happy Days
