Skip to content
Cheshire cat
Posts posted by Cheshire cat
  1. Thank you Tony. I can't see a balancing valve. I would expect it to be somewhere in the pipework next to the calorifier.
    I shall acquire one and fit it.
    It will be interesting to see how hot the radiators get if the calorifier pipe run is completely taken out of the equation. Of course, I've waited until the wrong time of year to investigate!
  2. The Revenue do go out and inspect from time to time. We had a visit from them at our boat club last year. They wanted to see our fuel facility and our record keeping.
    We have just recieved the necessary paperwork to fill in and send back for the last financial year along with the tax we collect on their behalf.
  3. I think it depends on your setup. On the previous boat we had four radiators and a calorifier heated by a Thermotop C. Everything was nice and hot by the time the Webasto started cycling.
    With the current boat we have three "designer" radiators and two towel raidiators + the calorifier. The Thermotop E throttles back after an hour but the radiators and water are only middling warm by then. I'm not sure if I'm expecting too much. It does start cycling eventually but we're probably two hours in by then. I think the unit has probably done less than 1000 hours.
  4. When the Bridgewater breached almost two years ago it was quite entertaining watching the local farmers trying to deploy the stop planks.
    Some were rotten, some were swollen to a state that they would no longer fit into the slots. I witnessed one guy break his sledgehammer shaft trying to persuade the planks to fit. In addition to the stop planks quite a few builders bags were deployed. It was a good 24 hours before they managed to stem the flow to a satisfactory degree.
  5. 3 hours ago, David Mack said:
    Ah. One of the advantages of an ancient consumer unit with rewirable fuses is that it doesn't have circuit breakers incompatible with plug in solar.
    I also still have an old fashioned mechanical meter. Will that run backwards if plug in solar generates more than I am using?
    A friend worked for a meter manufacturer, Schlumberger if I remember correctly. The various leccy companies coud have had a meter with a ratchet in it that prevented it from going backwards but none of them thought it worth the extra cost.
  6. I think the only answer is yes C&RT do.
    We moor on online moorings which are rented from CRT. The price inctreases according to how much comparable CRT moorings have increased. I have two issues with that. One is the unpublished  cost of comparable moorings and the other is the level of occupancy.
    I have passed two online sites this year that have  both been dire!
  7. I've just arrived home after a dreadful cruise. Sticking on topic the T&M at Etruria is full. Coming south is variable, some pounds full others are significantly down. No rhyme or reason. Stoke south is good until you get to Meaford. Beyond that still variable. Pounds have been lowered below Weston to help with the repairing of the byewash at Hool Mill Lock but all in all cant see any reason to close the Caldon. Drove past Rudyard and it looks OK.
  8. Most is probably over egging it but certainly at least half.
    I don't remember the towpath being flooded on previous transits when all paddles were available.
  9. There's next to no chance of getting through in two days at the moment. Marple in particular is very slow with paddles chained up on most of the flight.
    We are heading south and have made it to Congleton. Even here the water is significantly down, probably 8 inches
  10. Interestingly the Bosley resevoir is currently 2.5 metres down on maximum capacity at the moment. This week last year it was 6 metres down. There seems to be a change in strategy.  I believe Combs resevoir is also relatively full.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
