Orakal
About Orakal
  • Birthday 26/01/1974
    Wolverhampton
  • Interests
    Most things technical and things that grab the imagination.
  • Occupation
    None currently
  • Boat Name
    Oddmedod
  • Boat Location
    Stafford
Orakal's Achievements
Engager
Engager (3/12)
0
  1. Im not sure thats the best angle, im goin again tomorrow so ill take some more detailed pics, whats the average clearance thats left between the 2?, as i can get some cut off when the welder comes.
  2. The boat is a 1976 Harborough Marine with a grp top....Ive unbolted the 4 bolts around the bottom of the swan neck allowing me to lift the rudder out the cup but it wont drop any further than its sitting now. Relocating it will be easy as i can lift it without much effort so no matter what i use its not a problem. I have never took any photos detailing the arrangement but the ones i have might help i dont know. I was under the illusion if i had a brass sleeve it wouldnt stay the course given the thin sleeve needed if i need a diametral clearance of 2mm.... If i used either brass or a hard plastic could it not be tighter and allowed to find its own seating or is this not a viable option? This boat has had this bad steering vibration since we had it so im wondering if a bush had been fitted prior and wore away and just never tended too. Im either going to have to go with a slip or a new cup, neither is an issue as the welder still has to return. Im looking to buy either piece from someone who can manufacture it for me obviously after i have taken more comprehensive measurements to ensure the bottom of the rudder isnt oval. So lets say i want a new rudder cup save worrying about the bushes wearing/fitting which i think is the proper way to go who can make and ship one to me in Wolverhampton. Can you provide me with a rough cost only please as well as everything has to be finalised. The skeg isnt bent and everything is straight and true
  3. The vibration when cruising is coming from the stated problem. There is so much play the rudder is actually banging in the cup and the swan neck visibly vibrates with a huge movement and as more water is pushed over rudder it becomes unpleasent at more than 50% power and with a lister sr3 thats not alot of power. I think a new cup is the way to go, just need someone to make it. Thats an idea i have toyed with myself as it will make a tightish self fitting bearing as such, im trying to get a long term solution though but if all else fails this seems viable.
  4. It all looks round to be honest, theres no visual signs of oval wear and with how long its had that much play it may well have worn round itself...might have been on for 38 years for all i know.Ill take more measurements to make sure.
  5. Thanks ill certainly keep them in mind, kinda thing im looking for and my welder can put it on no prob after i take the other off. I do concede that i will have to take more measurements after cleaning it all up more so i can see the true wear to see if as you all suggest its oval and if so replace the cup completely but can anyone tell me what an acceptable tolerance is around the rudder to the cup?, as i know 5mm is huge and very poor so what gap do i leave? If the diameter of the base of the rudder is 33.2mm for example, what size bore do i fit it into, 35mm...is that to small and abrasive?
  6. Hi, im in the middle of having the boat welded watertight and, since we have had the boat the steering has had alot of play leading to abnormal amounts of vibration so while shes out ive looked into it. There is a fair amount of play caused by the 5mm gap between cup and rudder as shown in the pics. So my question is what would you do. I need to know what tolerance is usually given to this arrangement before i go further as i dont want it too tight. Then im thinking i have 3 reasonable options, 1,Replace the cup completely with a more suitable one. 2,Try to get a sleeve made to reduce the play. 3,Try and get a bearing fitted to make a nice smooth motion. I can see the bearing being an issue down to corrosion and i know of another who did it and ruined the bearing when hitting something with their rudder. My other problem lies in the fact these are not off the shelf pieces so im trying to find somewhere that can turn me either piece i decide to use. So if you have a workshop and can make me the piece and ship it im happy to pay or if your local enough collect said item. Or if you can point me in the direction of a place that can make it me im happy to go along and sort it out, im in wolverhampton and the boats near penkridge stafford so anywhere within 10-20 miles of either is great. Thanks for your help.
  7. Thanks, and yes they are as i have sheared the head off a dodgy bolt already with no damage.
  8. Yeah im aware 6mm is metric hence saying "about". It must have been made from 1/4 inch which i think is 6.35mm but im not pedantic enough to put that so 6mm sufficed as conversions carry too many decimal places for general chat. Given the fact every original bolt and fitting ive come across is imperial im happy to believe the boat uses an imperial steel thickness, something the surveyor also mentioned to me friday, who knows....she floats ,just....it'll do me.
  9. The reason its so strong might be because it was built in 1976 in the middle ages plus it was built in imperial so its about 6mm only. The other reason might be because its a through bilge something todays boats dont incorporate thank god as its a horrid idea. Added to this the length way strips support the ballast not the floor which i prefer personally, i wont even stand on our floor although it should be sound enough.
  10. We have our boat out now on your marina just inside the gate, after rescuing her from sinking last saturday..It was surveyed yesterday and only fails on the swim and the plate above after spending many years with a wet through bilge and alot of rust...best advice we were given was to remove rust dry and recoat and keep it dry and well ventilated.We did the majority of the boat floor when we had her 5 years ago and its lost barely anything and most measurements were 4.5 and above. Were just doing the last 8 feet now since its being redone inside and it looked like this throughout with wet soggy rust holding the water all the time.(sorry for pic quality) After scraping, Then painting, After all this the base plate has suffered very little if any, most important thing being get the rust out as ours rotted from the inside out. .
  11. Ill be trying one of those i think, thanks Sounds ideal but i fear it would be 14 days crates of beer and numerous curries. They look wicked and much fun, ill see where i can get them from, thanks Thanks i will, i usually buy from screwfix as its nice to have a point of sale you can return too in the eventuality its rubbish.
  12. Hi i have a 1976 harborough marine with a grp top and its just had to have a hull survey as i put a scraper through the side where the rear swim is and she started to leak. Its due to be surveyed next march for insurance so it had to be done soon anyway but we needed to see if it was worth keeping. Thankfully she only needs plating at the swim and the uxter plate so we will be keeping her. The other recommendation though was for us to remove all the old blacking as its that thick it just chips off and is quite pointless so my question to everyone is with the exception of scrapers how can i get this off as im sure sandpaper no matter what grit i use will clog instantly.The surveyor did mention something that goes on an angle grinder but i didnt catch what.Im assuming its some kind of wire brush arrangement but if someone could point me in the right direction that would be great. Also if anyone who can weld would like to come to st19 and quote me for the welding job message me and ill sort out a meeting.I do have pics of the places to do and measurements on phone and ill add them as soon as i can. Thanks.
  13. Cheers ill be doing that That stuffs awesome, ill be adding that to the boat once shes in the water again, thanks
  14. Its a plan but i think the insurers might want a little more reassurance than some hammer wielding maniac belting the boat to consider it insurable again. I do intend to do some testing though along those lines.
  15. Cant really travel far in it due to the very temp fix sadly, having it craned out where i am on Monday but i need a welder and a hull surveyor if anyone can recommend one?
