just wondering where on the canal side there is either a farmers market or any other type of market .Skipton farmers market on Leeds Liverpool is held right on edge of canal in the canal basin.
its like this but i have no steps in the rear deck which makes it inside like innisfree thanks for replies its helping me a bit im sorry not replied earlier, ive been spending as much time as possible fitting the inside of boat and engine as i can
thanks all im just building boat at moment well fitting it out and putting in new engine ill let you know how it works when i fit it just got the portholes to fit
just wondering any good ideas for a set of steps on a cruiser stern where the door is at the side at back,not in the middle some pictures would be great the steel deck at back is flat with no stair dropped into it
you have obviously turned the water off when youve done that open a tap to release pressure then turn fitting half a turn anti clockwise but dont turn it till it gets tight or you wont be able to push the plastic washer top towards the fitting then pulling the pipe out whilst holding the washer in as blackwrose says if the insert if fitted stays in the fitting you can do as is suggested but if you cant get pliers in just keep turning fitting anti clockwise until it comes off just make sure you keep the blue ring and the black ring and put back in same order as you removed it put in new insert and put piope back into fitting making sure you push hard enough for pipe to be seated fully then turn nut clockwise job done
Just thinking out loud and hoping im ok but i am putting my isuzu engine with prm 120 box in my boat for me to align my engine to within the required tolerance 0.05mm i will have to lift it 41mm would it be ok on rolled steel hollow section steel sat on bearers which are already fitted.Then drilled and bolted down through engine mount.I am considering fitting centrflex coupling with sacrificial plate, however could be talked into python drive any advice greatfully received
thanks been down today put engine mounts on engine. Measured up for prop centre off of engine beds they seem very low i need to lift engine up another 45mm to center it
This happened outside my house with a bloke who kept walking his dog as they are a creature of habit it kept sh 1 ting on the path my wife asked him to clear it up nicely .He turned round and told her to f off as he couldnt be bothered with that sh 1 t.So i decided to save the stuff in a carrier bag for a week followed him home on his daily walk and tipped it out on his front door step and said to him now tell me to f off because you cant be bothered with that sh 1 t . He doesnt walk his dog past our house anymore surprise
rough neck kindling splitter about £18 also roughneck wood bomb about a tenner dont wish to appear rude but the most important thing is learn how to sharpen it correctly and like all hand tools will make your work a lot easier even a cheap axe with wooden handle sharpend correctly will work good and the good thing is sharpening wont cost you money
does the toilet smell when your not using it also does the liquid waste evaporate because of the air circulation and where do you put the waste when you empty it sorry if i seem a bit of a nugget asking these questions
you could connect a Y fitting run hot pipe to one end cold to other and washing machine to single end put taps where you can easily turn on and off and hey presto if the water doesnt over balance its pressure you might be able to run at about 30 degrees by getting the mix right
