RobertG
New Member
Everything posted by RobertG
  1. Hi All, Recently bought a Seamaster 23 with an Enfield Z drive. Having similar issue as above. I can change from neutral to reverse but is very stiff, when I try to engage forward it is even more stiff and the engine stalls. I have replaced the control cable as I was advised that this could be the issue. When replacing the cable I tried to change gears by hand with the lever on the outdrive but it was very stiff. Could low oil level cause this? I am nervous about opening the level check screw as the boat is in the water. Any ideas or advice on this would be greatly appreciated. I just need to get the boat shifting gears so that I can move it to a place where I can lift out and do a proper service. Thanks in advance.
