I have a problem with the bow thruster in my NB and am seeking some battery and charging related advice please so I can decide best way to move forward.
I purchased it a few months ago - first boat I’ve owned and loving it, although I’ve rented boats for holidays over many years - and it came fitted with a 24v / 8kw bow thruster. [Aside: I know some folks opinions on BTs , I know they’re not essential but at 68’ long I’ve found it quite useful as a manoeuvring aid at very limited times when reverse mooring etc, so appreciate to keep advice away from ‘you don’t need one’ 🤣].
Current immediate problem is it will provide initially good thrust, but for only 2 or 3 seconds before stopping completely. I believe the reason is, because initial thrust is good before expiring the current batteries are shot - so once I confirm this I will need to replace them. It currently comes fitted with 2 x 12V 180aH dual purpose (which I understand means suitable for both general purpose or starting purposes) leisure batteries, sited very close to the BT. So I have 2 questions:
1. Someone has told me that although the current batteries are ‘dual purpose’ leisure batteries so theoretically should be fit for purpose, they would recommend replacing with dedicated starting/cranking batteries. These would however be a lot more expensive, so does anyone have experience/knowledge of the trade-offs of dual purpose vs dedicated starter type?
2. Once I select and fit the replacement batteries, another dilemma: currently the BT battery is only charged by the engine - not shoreline. But looking at the scenario of using a BT, it’s typically used for a short time with very high power - and often when coming to the home mooring, just before switching off the engine and switching to shoreline power. I’ve heard that unless you can ensure the battery is kept fully charged for most of the time, a new battery will quickly be destroyed. I’m not a live-aboard and can’t typically run the engine for an hour after coming home, so in folks experience should this be a real concern? If so I’ll then look at options for adding another dedicated 24V charger which could permanently trickle charge from shoreline power (main concern being to add more cost/complexity)
Any constructive advice gratefully appreciated.
