RosieR
Everything posted by RosieR
I’ve had some reassuring conversations that indicate you’re right! I’ll send back the charger😁💸 I kept finding advice on needing a smart charger but it appears that I don’t😁 thanks for taking the time to reply
- 5 replies
- 1
- smart charger
- ctek
(and 4 more)
Tagged with:
Can anyone help? I’m changing my batteries to AGM and need to install a DC/DC charger (CTEK D 250SE, which I have). I’m not sure if my battery is even using a battery charger at the moment. is that possible? I’ve tried to install it but I’m not confident enough to be sure it’s done correctly so I was wondering if any boaters on here have experience with installing this charger? Or if anybody has a number for a boat electrician who can help that wouldn’t break the bank (London, W10 area).
- 5 replies
- smart charger
- ctek
(and 4 more)
Tagged with:
It’s my first time changing over batteries so I wasn’t even aware you could adjust the charger! All the information is overwhelming, I’ll look into all of that, thank you:)
Hi there! My sealed lead acid batteries are nearly six years old and unfortunately they won’t hold their charge so Ive done a lot of research and just bought two AGM deep cycle 150aH batteries to replace my current two 200aH lead acid. My battery charger is a fairstone ABC1230 Fully Automatic 5 Stage and I’m pretty confident they’re compatible. My last fear is that I haven’t changed my starter as it’s still in good health but it is lead acid. Will having two battery types negatively effect the health of my batteries?
Hi Richard, thanks for the advice! Sounds great I’ll have a look.
- 47 replies
Sounds like that’s it! Thank you!
- 47 replies
- 47 replies
Great thank you for that! I will use the last of their life to do lots of research before investing in new ones:)
- 47 replies
I can’t find any buttons on my gear but I’m sure I’ll find out how to adjust it with some investigatory research! They were at the top of my list because of space saving so thank you so much for the tip off!!!
- 47 replies
- 47 replies
Great idea thank you! Do you know how long solar panels last as well?
- 47 replies
That puts my mind at rest a bit! I’ve tried searching everywhere for how long batteries should last and the results are really varied some saying 10 years!
- 47 replies
Both of the batteries are fully encased so can’t get to them without taking them out of the box I think. yes that does sound a bit above my knowledge, I’ll have to rummage the internet to try and understand the system better! It sounds like I’ve also been undercharging severely if 3-4 hours is advised… with the rpm, that’s the rpm of my engine, I’m not sure how to change it without coming out of neutral, is that something I can do directly on the engine? thanks again for your help
- 47 replies
Thank you so much for this help it’s extremely helpful! I’ll take a look at that link and definitely invest in a better reader… and it sounds like some new batteries as well😂 right now the voltage is 12.58
- 47 replies
Hi! Thanks for your response:) I charge between half an hour and two hours at 2800 rpm. I’m not sure what you mean by end of the batteries blowing out, is that a physical change? I haven’t touched the physical battery I don’t think I know enough to move anything 😂 I’m getting tired of being scared of it though so I’m ready to learn as much as I can! I’ve experimented with different charging times and it hasn’t seemed to make a difference. I’ve only let the battery drop below 12v twice in the year I’ve been on it according to the solar reader so I hope it’s not persistent undercharging! it sounds like “sulphated batteries” how do I trouble shoot that? thank you again for your help
- 47 replies
Thank you for your response:) 1. I run my engine between half an hour and 2 hours a day, no hook up 2. I have a very simple voltage reader mounted in the wall (pic attached) 3. The only way I’ve been tracking my daily use is on the solar controller, what else would you suggest? 4. I haven’t, I’m terrified of actually touching the batteries, I still have ALOT to learn about 12v systems 5. I’ve had her for a year and I live on her full time. thank you in advance for all your help!
- 47 replies
Hi! I have two 12V 230Ah domestic batteries with two large big solar panels, a beta marine 43 that seems to charge the battery well (I’m pretty sure it’s not an alternator problem). The issue is that my batteries seem to drain SO quickly. Just charging phones the level sits around 12.9ish but I can put my lights on (LED) for literally 3 minutes and my voltage will go from 12.9 to 12.2. I don’t have an inverter, I use a plug in 12v inverter to charge my laptop and I cant use that at all without the engine on. I turned my 12v fridge off at the end of summer as the days got shorter but as the suns put more the battery health seems worse than ever! The batteries are 6 years old but maybe they’re just old but I’m not sure. Any comments would be incredibly appreciated! And any advice on maintaining battery health ❤️
- 47 replies
I don’t have Facebook, is there anywhere else to check?
Hello! Does anyone have a number for a coal boat around Kensal Green? I can’t find anyone that will be less than a couple of weeks
It starts to whir, it gets loader and loader , it sounds like it’s trying to pump something round then it just stops That makes sense! Do you know what the culprit could be for over heating?
It’s not a pressurised system and I filled it up fully when it started having problems (about 5 days ago), thank you for offering advice
No clouds of white smoke in the engine room, I didn’t see any from the exhaust either. It takes its fuel from my tank which is nearly full, I have been advised it could be an airlock in the fuel pipe
Less than a week ago it was working, only in the past 4 days or so it’s been a problem
That makes a lot of sense! Should I try running the engine before?
