I don't know if you lovely people can help me again? I'm having more Water pressure dramas... I've googled and googled but not sure ive got the answer.
Basically... I got a new water pump, fit it, all is well. The pressure on the water pump is 45psi.
On stripping out the bathroom ready to fit a shower, i found a random in-line pressure switch. not sure if it was doing anything or whether or not it even works... Anyhow.. it was leaking. So i took it out and connected the pipes back up directly thinking..... My pump has a pressure switch in it so surely its not needed?
Prior to this... i found my water pump kept running on after I had turned the taps off.... The water would trickle out of the pressure release valve on my calorifier for ages before it turned itself off. It was also turning on on its own so I figured I had must have a leak (which I found and have now rectified)
Anyway... Long story short... 45psi Pump goes to calorifier now (directly, no in-line pressure switch) and water just continuously pisses out the pressure release valve. The Valve is a 4bar valve... which using google is 58psi? - So in theory.... we should be good? no? If i tap the red bit on the valve... on the calorifier, it stops. Until
I turn the tap back on again.
Its a relatively new calorifier (just over a year old) - Could the valve be faulty already? or was the in line pressure switch actually doing something? Is my only option process of elimination?
Am i being thick? i don't even know anymore.
