Piran
Posts posted by Piran
The electrolyte level is fine and has been since I noticed the bubbling. However, when I last topped them up a couple of months ago unfortunately some of the plates were very close to being exposed or exposed slightly as I had forgotten to do it for a few months. It is also possible the solar controller has been overcharging for a while (which I perhaps didn't notice until recently), which perhaps has damaged and not allowed them to recover...
Thanks @Tony Brooks. The batteries were installed in 2016, trying to gather if that makes them quite old and prone to plate issues?
As the charge is dropping at a slow rate does that make it less likely there is a leak of that sort?
Thanks for the responses! Haha I did wonder about there being a mouse down there but definitely seems to be the batteries! It is odd... is it possible that one of the batteries could be doing less well than the others causing current to pass between them?! Not sure if that would explain the continued bubbling.
Would someone mind explaining what a 'shorting cell' means?
Cheers again!
My Trojan open batteries were being overcharged, thought to be due to a fault with my solar controller. Since Friday (4 days ago) they have been disconnected from the solar and haven’t been charged by the engine. Their voltage is now 12.6 and they are still displaying symptoms of over charging such as make little squeaking noises and produce a small amount of bubbles seen rising from the plates.
At no point have they been hot or making a gassing sound when opening the terminals.
Is this normal? How long can I expect them to bubble or might something else be going on?
15 hours ago, Richard10002 said:
I used Vactan, then Craftmaster primer, undercoat and bilge paint, on my very rusty and wet engine bay. Still looks like a good job a few years later.
Dont know anything about Craftmaster rust treatment.
Oh and what process / tools did you do to get rid of as much rust build up before treating? I have a metal scraper and sandpaper but wondering what else could be good!
Ah ok cool, maybe I will go
all craftmaster
Gearing up to paint the accessible portions of my cabin bilge and wondering if there is much variability in rust treatments? I have plenty of this one left over from treating my weed hatch cover but want to make sure I am using some thing well suited to the job.
I have a condensation issue in the portions of my cabin bilge that my back boiler pipes run through. Any recommendations of primers/paints to use in bilges that are damp prone?
Can't get hold of the yard as it is good Friday but would like to know if this is a standard practice in grit blasting
Have been using whatever I can get my hands on so far but I know some are definitely better than others. Do people tend to prefer certain kinds due to their heat output or other factors?
Hmm, starting to wonder from a bit more research whether a header tank is an expansion tank (sorry for the tripping up on this)
Well, we have a header tank but no expansion tank...
There also isn't a drainage system
Do you know if having a header tank in fact means that it is an open/vented system?
right so after a lot of searching and a call with the previous owner I have realised that I actually have a closed, pump system. After experiencing an (electrical) pump failure yesterday we are quite keen to just disconnect the back boiler and use the stove on its own. Would rather just have the stove without the stress of the back boiler at this point. Any tips for disconnection? Wondering if we can just unscrew the back boiler entry and exit pipes and let the liquid in the back of the stove burn off or if we need to drain the entire system and remove all the pipe work?
Getting pretty chilly so keen to get the fire on !
Thanks very much all of you. I will do those things tomorrow and will definitely be looking to update the entire fuse system ASAP
Ok, will do!
What is weird is that the pumps have started working again, then all stoped, and now have started working again. Can it be a fuse problem if this is happening.
Our smart gauge says we have 81% charge in our batteries. It has been a sunny day and we have four solar panels, lights are all working etc
28 minutes ago, Tony Brooks said:
Please clarify that you mean the bilge pump, shower pump and domestic water pump or if you mean nothing comes from the taps. If the latter check that you have 12V at the connectors close to the pump with the pump still connected. If so I fear its either the pump has packed up (brushes) or the pressure switch has failed open. If the former you need to start checking voltages with things connected turned on while working down the circuit to find where the voltage goes away
My engine bilge pump is working. However my shower pump, domestic water pump and back boiler pump have failed.
nothing is coming from the taps and nothing is able to be pumped out.
Im not really sure what I am doing but I turned the batteries on and off and tripped the fuse box (I have one central fuse). Immediately after doing this the pumps didn’t start working). However, about ten minutes later they starting working for a brief period. I used the bath room sink tap, but when I went to pump it out the pumps all failed again
Yes there is definitely water in the tank. Filled it up a couple of days ago
- 1
All my water pumps for bringing water to the taps and water out of the boat have stopped working at once. I have full solar charge, lights are on and all other electrical outlets seem to be working.
I have turned the batteries on and off and checked my fuse box (it hadn't flicked down but I tripped it anyway but no luck).
I have been really struggling to find the drainage point in my system. I have traced the pipe work around the boat and under most of the floor boards I can get up without breaking them. Would anyone be able to send a picture of their drainage points so I might get a slightly better idea of I do find it?
Great, thanks will do. Just trying to locate the drain, any clues on where they are usually situated?
Cheers again
Thanks Tonka, would it be advisable to drain the system prior to adding the new solution or is this not necessary? not sure what was used in there before
How long to open batteries take to recover from overcharging?
in General Boating
I need to just check as my electrician took it, but it was definitely over the normal amount
