Days Won
3
Posts posted by Tracy D'arth
I have never worried about booking, the boats off the Bridgewater don't seem to bother when and how long they are on the C&RT waters in my observations.
Is the key switch out in the weather?
Hob Bright for electric solid cast iron hobs works fine and is easy as it is in a loaded foam pad.
Fit it so that its the first thing to hit the other boat broadside.
- 1
- 1
6 minutes ago, blackrose said:
Is it ok to just whack any old air filter onto an engine? I would have thought the engine spec is relevant here? Different engines will require different amounts of air and if the random filter you happen to fit restricts air flow too much that wouldn't be a good thing.
Not likely to matter with a slow running underworked motor in a canal boat.
- 1
I have no idea what that message means, is it in the instructions or if you ask?
Try disconnecting it from the batteries for an hour, it may reset. Are the batteries fully charged? Did it do this because the engine was running? It must be either over volt or under volt trip.
Something like this K&N air filter.
https://www.demon-tweeks.com/uk/k-n-filters-universal-round-tapered-air-filter-244169/
- 1
You should still get the relay to connect when you rev the engine. It will just take a lot longer to get the batteries fully charged which you must do to prevent them sulphating and dying prematurely.
12.8v is fully charged for a 12v lead acid battery.
Or do you mean the alternator is only outputting 13,1v instead of 14v and a bit more?
Just now, Tracy D'arth said:12.8v is fully charged for a 12v lead acid battery.
What split charge relay is it that monitors the voltage? A relay does not do this. Do you mean a voltage sensitive relay? Which?
I cannot see why this is a problem. Does it not connect the cabin batteries?
The usual way is to charge the cabin batteries first, then connect the start battery as it needs less charge.
4 minutes ago, Tracy D'arth said:12.8v is fully charged for a 12v lead acid battery.
The SR2 is difficult for charging because the alternator runs off the cam shaft at half engine speed, you need a large pulley on the cam and the smallest pulley possible on the alternator.
1 hour ago, Manxcat54 said:
There won't be water on this boat
🤣 😁 😆 😂 😇 🤠 😏 No condensation then ,,,, ever?
What degree of resistance is the question.
The occasional splash or the occasional dipping in water. Or on a boat the permanent water sloshing underneath and the condensation 9 months of the year.
I have seen loads of houses with weetabix under radiator valves that drip a bit.
I have also seen lots of boats with spongy chipboard floors.
2 hours ago, Manxcat54 said:
It's 22mm Caberfloor and better than any of the ply around, it's very solid, it's not CHIPBOARD
Its moisture RESISTANT CHIPBOARD !
Ugh! Chipboard floors in a boat, seriously bad idea. I know marine ply is not was it used to be and expensive but you would be better off with Resin bonded OSB.
31 minutes ago, pedroinlondon said:
I undestand. Those are for the "standard posts" which are smooth and unthreaded. To avoid them and use cables with ring terminals I need a battery with threaded posts, or am I missing an alternative?
Sorry Tracy,which connectors are you referring to? Some kind of adapter from standard to threaded posts?
ThanksNot really, these are what everybody uses https://www.ebay.co.uk/itm/156142610396?
21 hours ago, Peugeot 106 said:
I think it’s called “ galling” and can happen with any metal fastening but is a particular problem with stainless bolts into mild steel. I didn’t have any problem with my window screws but they were lubricated with mastic as it’s caused by friction
Yes copper grease would be ideal
I use a bar of soap.
To be clear, tapered posts are fine but the clamp connectors must have a threaded stud with nut to take a crimped on cable lug, the nasty one illustrated with pressure screws onto the caple are not OK Solidly soldered cable into the connectors as are generally on made up battery cables are also OK.
5 minutes ago, pedroinlondon said:
I'm trying to find a starter battery of 700CCA or above with nut terminals but cannot...
I can only find with I think it's called "standard posts" which are smooth and unthreaded.
Can anyone confirm that the BBS rules require that the batteries are threaded and adaptors are not allowed, or was I wrongly advised?
Example: https://www.tayna.co.uk/car-batteries/yuasa/ybx5110/
There is no restriction on using threaded posts with nuts or the traditional tapered lead posts either. Lugs with nuts and bolts are also perfectly OK.
I used to install 'phone switching centers. The battery makers insisted on every connection on the 48v racks being cleaned and covered totally with the supplied packets of grease, which was actually the same as Holts No-Crode.
And they were thousands of amps @48v !
On 16/04/2024 at 19:04, Rankingjonno said:
Fancy doing it again? 😉 Ours are a wreck...
Thank you all for your expertise - the intelligence of this hive mind is incredible!
I am a bit passed lying on the back deck grinding and welding those panels under the stern gunwales! They are fiddly to get at.
And why the standard railway gauge is 4' 8 5/8".
It was the width of the wheel ruts from the horse drawn carts.
1 hour ago, blackrose said:
Vaseline non-conductive and a good electrical insulator. If you apply it to the terminal surfaces and then refit, most of the vasaline will be squeezed out but there will still be a thin film between the surfaces increasing resistance, which kind of defeats the object of cleaning them in the first place. If you clean the terminals, refit and then apply the vaseline to the assembly to prevent long term corrosion that's better, but if you take it apart again you must make sure that you thoroughly clean all the vasaline off before refitting because the stuff gets everywhere. Personally I don't bother dressing battery terminals because I think it's more trouble than it's worth.
Utter claptrap. A minute coating of Vaseline or No-Crode will not insulate a clean, tightly clamped post and clamp terminal connection.
IMO the dome head stainless screws look far better than pop rivets, well done.
58 minutes ago, alan_fincher said:
Yes, I'm sure spud has it. I was also coming up with Mindon Marine.
Excellent, I knew that the stern was familiar. 24 years ago I welded all the interior stern panels around one of these. I was told by the owner that 41 feet was a popular size for Minden Marine as it fitted in the workshop!
I don't rate the minimalist bath on the roof, or is it a Cressy water tank?
Just follow the heavy cables rather than guessing.
3LW tappets
in Gardner
If you get the valve you want to adjust fully open then turn crank one full turn exactly as Tony said, the valve must be full closed then. Works for any engine with any number of cylinders.
