Hi All,
I added around 500w of solar to the roof at the beginning of the year, and though it seems to be working just fine I have a couple of ideas that may improve things.
Firstly is the connection of the MPPT into the batteries.
i have a fairly cheap 40a mppt, standard amazon chinese job, it seems to work well in isolation, however when i start the generator (no shore power) to charge via my 1500w Invertek inverter/charger (stirling rebranded) the mppt display shows a huge reduction in charge current, I'm guessing because the control circuits in the mppt see the terminal voltage as quite high as it is being artificially boosted by the charge voltage from the inverter and believe the batteries to be "full" and thus reduce the solar current?
I'm looking at reconfiguring the system to take the most advanting of the solar and have a couple of direct questions!!
Firstly, My Invertek inverter does have provision for solar input, it lists several compatible MPPT's which unsurprisingly are all Invertek branded and stupidly expensive. Is it necessary to specifically use an invertek mppt, is there any data communication between the inverter and the mppt which would make it brand unique? If it is compatible, would it be a better place to connect it than directly to the battery terminals in parallel to the inverters connection.
Secondly, there are three pairs of terminals on the MPPT, obviously panel input and battery output, the other pair are marked "load" I have left this disconnected as most of my pre-distribution cable is 95mm2 and the terminal struggles with 6mm2 Do I need to find a "dummy load" or something to connect to this?
Thirdly, can the assembled think of a better way of doing all of it???
Thanks in advance,
Bex
