Hi All,
Does anyone know of any moorings or plots with a bit of land on the Ashby Canal (top end, stoke Golding to snaretone) must be able to finish boat!
thanks in advance
Tony thanks for your response pmsl I actually haven’t got a clue about marine engines! As it’s water cooled I thought it sucks water from the river cools the engine then spits it back, my thinking is that coolant would pollute the river or thinking about its probably stored separately ??♂️?
Excellent! Sorry about the description Tony, and yes I have just lossened the lock bolts which has as you said loosened the tension, just adjusted tension once belt was back on. All sorted! You will make a pro of me yet ????? thank you #legend ??
New problem! Started engine tonight heard a clang and stopped engine, looked and cam belt and whelk has come off. Obviously whoever put it on didn’t tighten bolt. How do I get back on without stretching belt?
All fixed checked what most people advices no water coming out back so I screwed water tap in instead of out! And all working again ha ha ha ha ha sorry to waste your time guys and thank you for your support
