Strettonman
Content Count
70 -
Calendar
Community Map
Everything posted by Strettonman
Not sure anyone is really interested but here is my attempt so far. I lined the foam covered calorifier with tin foil and then built up 2 sections of slight loose bubble wrap and injected fire retardant foam to create about a 1” layer. Once (sort of) set I put on 3 sections of very loose bubble wrap to create a second layer another couple of inches thick. I’d ordered 1m wide bubble wrap but it was out of stock so they gave me several 30cm wide rolls. This was actually better for getting the foam in. the only problem is it is taking days for the foam to set as the air can’t get to it. nex
That’s excellent - thanks everyone. It looks like I’ll be spending this evening on eBay. cheers.
I’ve currently got an unlimited data package sim in an old smartphone used as a hotspot when we’re onboard. The signal is often ‘patchy’ so I am wondering whether a proper mobile router would be a better solution. I’ve currently only got 12v power so I guess I’ll need the right lead/converter if I use a router designed for the home. Also are there any tips on getting the best signal (router location, additional external antenna ....)
The calorifier is in the engine bay of a cruiser deck so I little exposed. I am in the middle of rethinking the layout and may put the kitchen at the back so could quite easily move the calorifier inside but I suspect this might end up being next spring.
This is great stuff all - thanks. Sorry for a late response - a common boating problem (or joy😊) - lack of signal. I’ve routed the pipes to the engine that seem to prevent siphoning and I’ve also got a manual valve to shut it off if need be. While I want to maintain heat over night my main concern is freezing in the winter. We live aboard part time normally 3 days most weeks so my main concern is to minimise the risk of damage between visits and not have to drain down the system every time I think there is going to be a cold spell. obviously if the forecast is sub zero for weeks I migh
My calorifier is in the engine bay and I’m considering how to add additional lagging. I’ve seen posts about adding jackets and wrapping in celotex sheets but was also considering creating some sort of cylindrical frame and using expanding insulation foam and wrapping the cylinder in aluminium foil. The foil would not only reflect back the heat but also enable me to get the foam off the cylinder if it all goes horribly wrong 😛. any ideas on which gives the best insulation per inch of thickness as space is at a premium.
Ouch - just looked on eBay and it looks like anything from £150 up to £300+.
How go I go about choosing a new alternator controller? I have 2x120Ah leisure batteries and have room for a third (which I am considering). I will shortly be adding a couple of solar panels. we generally live aboard for part of the week and in the summer boat most days and in the winter a few hours every fortnight - not that all that info will make much difference I suspect. also are they easy to fit (or should I say difficult to screw up) ?
Thanks the switch doesn’t jump back. I will give acorn a call and spend a little time reading those other threads. I’m about to add solar so I may well bite the bullet and replace the alternator controller to something from this century. Thanks.
Can anyone tell me what the switch in the side of the kestrel 90 alternator control does (see pic). I have no idea whether it should be up or down and I’ve just swapped out my batteries so I want to make sure it is not in a mode that might damage them over time. i gather there are all sorts of fancy modes for charging as the batteries reach close to capacity so suspect the switch may be related to this. any ideas ?
Wow - thanks everyone for these very detailed responses. As I suspected, it is clearly not a case of buy a piece of kit and all will become clear. I’ll spend a little time today trying to get my head around your advice and will certainly come back with further questions. Thanks very much.
I am considering fitting a solar panel system and just wondered how you monitor the state of charge of the batteries. I presume there is a monitor I can buy or it is integrated with the controller but how do they work ? Do they measure energy in and out and then estimate the SoC ? If so it guess some will be better than others so does anyone recommend a particular unit ?
Removing a bent ignition key
Strettonman replied to Strettonman's topic in Boat Building & Maintenance
Thanks all, looks like I’m off to get a spare just in case and then try A bit of hood old brute force with my fingers crossed. cheers -
I unfortunately left a slightly bent ignition key in the key box and my better half tried to use it to start the engine (see photo). It worked fine but because of the slight bent at the shoulder of the key it is now stuck in the barrel. I’ve been reluctant to force it as it may snap off on the barrel and I will then be unable to start the engine. I’ve tried WD40 with no joy. any ideas?
Great advice - thanks.
Got a fairly small boat (40ft) so not much roof space and I am looking to buy a couple of solar panels. While eventually I might get an inverter I am currently all 12v and I plan to live aboard 2 or 3 evenings a week to save commuting plus the odd weekend cruising. I was told you pay about £1 per watt then add on controllers, cables, mountings etc but I see on Amazon and eBay 100w complete kits for about £100 and single panels for less the £70. can anyone give me any guidance on makes and models for all the bits or is it a case of ‘you gets what you pays for’ with solar panels. I’m th
I’ve just built the walls for my barhroom and plan to use wetwall panels for the shower cubicle. what should I treat the inside walls with prior to sticking on the acrylic panels ? I was contemplating getting a big Tin of marine varnish but will this impact on the effectiveness of the panel adhesive ? any ideas or advice ? cheers
Thanks all, just ordered the gulper. Not worth the risk to save £50. Thanks for the advice cheers
I’ve just stripped out an old bath and fitting a shower. The old waste pump seemed to be a bulge pump in a chamber roughly the height of the bath. This seems a petty basic set up and looking online there seems to be diaphragm pumps with run dry capability. Are these the ‘modern’ solution ? also, some seem to be available for about £30 but the whale gulper 220 is more like £90. What is the difference and is it worth paying the extra ? any recommendations ?
Thanks everyone. I will leave it as it is. My wife has just reminded me that the previous owner had just replaced the pump before we bought it and it hadnt been used in anger since so maybe the rapid cut in and cut out after turning the tap in and off is not a good reference. With little previous experience of boats I’m never sure what is ‘normal’ and what isn’t. Cheers
I’ve just started revamping my water system and have a question regarding how long it should take for the pump to kick in and cut off. Before I started hacking it about the pump would kick in within a couple of seconds of opening the cold water bathroom tap and cut off 2 or 3 seconds after closing the tap. The tap was about 20ft from the pump and the accumulator was just next to the pump (mounted horizontally if that is relevant). Ive been rejigging the pipework with the accumulator now about 10ft from the pump and mounted vertically. It now takes 10-15 seconds before the pump star
Is there anything better than K99 stern grease?
Strettonman replied to Strettonman's topic in Build Blogs
Thanks - Morris is the stuff used before so I will stick with it. -
I’ve just started boating and the boat came with a pot of K99 grease for the stern gland so I have just been using the same. I’ve been looking online to replenish my stock and noticed K99 is water resistant but others are water proof so it started me thinking whether i should use something else. The gland does drip quite a lot and the boat yard say it’s not the packing but it needs a new prop shaft. I want to delay this as long as possible so if there is a better grease I’d be prepared to try it. Any my ideas ?
I’m in the process of wire brushing and degreasing my bilge/engine bay before repainting and wondered what paint people might recommend. Some have said specific bilge paint is a waste of money and I’ve always sworn by hammerite whenever painting metal that gets exposed to the elements. Any thoughts ?
ok - thanks
