Everything posted by Tasemu
What you said above makes sense to me, thanks for the advice. When i run the alternator the batteries are definitely at 12.3 - 12.4 resting voltage. Sometimes the voltage jumps healthily immediately, and sometimes it barely jumps at all. But it always climbs up to 13.9-14 volts fairly quickly, within a minute or two. Perhaps the belt is slipping when i start the engine sometimes. The slow initial charging voltage i see only happens sometimes, other times there's no issue at all. Sorry if my information is a bit light, i'm just working on what I see from the battery monitor.
Hiya, sometimes when i run my alternator the voltage jumps to 13.x immediately and continues rising shortly after. Other times, the voltage barely jumps to 12.6 before it very slowly rises to expected charging voltage. I put the alternator on at around 12.4 resting battery voltage. Could someone explain to me why this happens? Thanks in advance!
I've talked to him and he is going to have it looked at late june, but told me to fill it up and try to get it working. I kinda need to have some ability to charge my batteries. Not ideal I know. Yup i ran with the top off for a while, didn't notice any boiling, but will do it again now for longer, i probably ran it not long enough before i put the cap on. also i filled it up to almost the top.
No instructions, no operation nor maintenance other than to check the oil occasionally. all followed. I dont think the owner does much with this boat. He hasn't come to see it once since I moved on. He didn't seem to care much when I told him it overheated, but we do have a contract if the engine did indeed break down and I was unable to fix it, he would be obligated to get it running again. Legals aside though, if I can get it running again and work out where its leaking, i can take the advice here to him and hopefully he can get it fixed. I need the engine to charge my batteries for work, that's my main issue here. Thanks for the heads up. I see the former with the filler cap and will be topping it up today. However I'm not sure what the plastic bottle is, i do not see anything like that on the engine. Also thanks everyone for all the help. The feedback has been seriously helpful.
It is yeah, i'll inspect the hose today. I'm not sure, its been there since i started renting it. I'll take a picture of the dipstick and the level on it today, i try to keep it where i think it makes sense haha, but god knows. There's no drip tray unfortunately, i've never been able to pump it out enough to put in a tray that doesn't float away. Can't install a proper one as i'm only renting it.
Just stopped as i would have if i pulled the stopper plunger. Hey guys, so many replies! sorry i fell asleep! I've checked the pulleys and pump and it looks ok. I've checked the coolant tank.. looks dry as a bone in there. I'm going back to re-read all the comments now and reply to as many as i can.
