Chubb41
Everything posted by Chubb41
  1. Chubb41
    Starting
    Hi thanks I bought the boat of a friend BUT it hasn’t run for two years but he had had it rebuilt and only done9 hours there seems to be a lot of compression But will do a test on that in the week the engine did run and funny you should say about the turning over a lot of cars won’t fire if to slow turning over could be the injector Dumping fuel in ? Thanks Chris
  2. Chubb41
    Starting
    Hi all ? does anyone have any experience with Volvo Penta 2001 not starting white smoke out the exhaust seem bleeding might be a problem? And there doesn’t seem to be heater plugs on this model ? thanks chris
  3. Thanks the engine is a Volvo penter 2000 series and then Enfield 130 I’m thinking of charging the battery from the alternator as the alternator seems to have another live feed from also so I can use want to charge alternator and want to charge two leisure batteries or maybe switch to directly calling from the starter battery to the leisure batteries when the battery to start the engine is full then from you leisure batteries to an inverter ? I will be living on the boat and it’ll be just a small fridge for milk etc and sockets just to charge my phone and the TV that’s hope this helps chris ps Thanks for all your advice ps 12v over 240 ?
  4. Hi all I’m looking for some help I’ve got a dawncraft and I’m at the stage of putting electrics inside at the moment I have just the one battery to start the engine I believe I need to leisure batteries and inverter I will need power for fridge TV and charge points I am a mechanic so the engine side I’m okay with basic wiring but unsure what inverter fridge etc to buy thanks Chris
  5. Arrrr ok I’ll try that also I take it so the gears mesh with propeller turning slightly? thanks again for all your help Chris
  6. Thank you so much for that I’ll try that I’ll probably have to cut the little Allen key bolts off and re-tapp them as there is not much left and there probably steal used with alloy electrolysis !!!! ?but thank you so much for that tip Chris
  7. Er not sure what to say here lol I just wanted to know if anyone had come across the same scenario I might not of said Exactly what I meant i.e. the history of the boat and everything all of the needed to know is if the gearchange lever can seize where it comes to the casing i’ve been a mechanic all my life And came across many difficult situations this is not a difficult situation by any means I just thought someone might have come across this before but thanks for your help and what great help it was thank you
  8. ok Thanks for the help I’ll take it off myself and have a look I’ve got all the diagrams I need it really can’t be that hard thanjs again Chris
  9. Yes that’s the setup and the two cables go to the control box as you said one to the engine and the other to the drive the cables are all free it’s the short lever that’s stiff thanks Chris
  10. There are no cables on it or the engine as I’ve had the engine out and I don’t use wd40 as it’s no good for that job but thanks for your help Chris
  11. Hi sorry yes ? the boat is out the water and had it about 8 months I bought it if a good friend he took it out the water about one year before I got it it was tight and used a little penetrating oil on it and if freed of abit so I can get the gears and I’ll going up later so will take a couple of pics thanks for the reply chris
  12. Hi all im quite new to this ive got and x drive Enfield 130 the gear selector lever is tight I am able to move it but seems tight to me does anyone know if this is an internal problem or just shaft tight going through the casing thanks chris
