Jstupot
Everything posted by Jstupot
Thank you Tony Brooks, the rest can go do one you are condescending and up yourselves.
Could someone please clear this up for me. You are CCing and you have travelled your 20 miles, then what? I have heard many differing opinions. Can you turn around and go back the other way? Does the not going back to the same mooring within 2 months apply? Can you then move around a bit freely? seems there is a bit of a grey area here and nobody knows the correct answer.
Recently started a thread regarding me stupidly over filling the leisure batteries. After many replies, a couple of replies said it may correct it self after the battteries have had a good charge. Well obviously this is wishful thinking but we went for that. Today there was the rotten eggy smell of sulphur coming from the engine area, - batteries. Does this mean the end? Should I replace them?
Well the main issue is that although the old pumps water flow was too low, and yes we can control the flow by not turning the tap on fully now, the toilet flush is filling up way too much now which is causing the holding tank to fill up to quickly. Is there a way to control the flow of the toilet flush?
It's a Whale, not sure which model though. And sorry I mean flow rate to be exact.
Recently had the water pump changed on our narrowboat and the water pressure has been way too high since. How do you change the water pressure please?
No spillage at all.
Well yes, most were below the plates, so when I say empty I mean low. As for overfilled, well some are filled quite high to just below the filler cap. Since I have done this we seem to be losing charge a lot more. No spillage at all.
I overfilled the leisure batteries. They were all empty. What can I do to fix the problem?
Hello have just received our fan for the stove, but our stove is a diesel with a hob on top that is red hot. Can we stick the fan on the job or does it have to be placed on the edge? Sorry got the novice question.
Hello, and I will start by saying sorry, as I'm sure this question has been asked many times before. My partner and I are moving into a a narrow boat this month. We are really not sure how often we should charge the batteries on a daily basis with general living aboard in mind.... 12v fridge, lights(all LED), small use of mains with 240v inverter, charging laptop, little bit of t.v, and so on. We have a 58ft with a beta marine 43 engine. One battery for starting the engine and 3 large batteries for power. Could someone please have the courtesy of helping a couple of newbies please, and no smart ass comments. Also is it fine to just have the engine running idle or does it need a bit of juice then charging?
Hello everyone, I'm a new boater and will be doing some cruising in and around London. This post is now 5 years old and London is forever changing. Could you please give me more up to date info on this thread.
Thank you all very much for your replays. Will give it a good clean. It definitely has had a lack of activity.
Hello. Just bought a narrow boat with a lock gate fei's all stove. Haven't yet managed to light it. Think it needs a clean. Have been told you can buy some tablets that do a thorough job, but do not know the name nor where to buy the tablets. Any ideas anyone please?
Thanks everyone. Very reassuring.
Thanks Arthur. I could see the prop through the weed hatch and there was nothing attached to it. Thanks Matty. That could make sense as there noticeably more leaves around today all over and in the boat. I hope this is the problem.
Thanks Tonka. By the way I have passed Tilly somewhere in the area. Not sure if we are confident enough to do that ourselves, but at least we may have some idea of what we are looking at.
Thanks Tonka for the the useful reply. No it's not Tilly. Is this a simple problem? I'm assuming we have to go to a boatyard to get it repaired!
Hello, today my partner and me took our recently bought narrow boat out for the first time along the Grand Union near to London. At first there were no problems, but then the propeller seemed to be struggling a bit making regular knocking sounds as if it was continuously hitting something. I thought maybe a plastic bag or weeds had got caught on the prop so pulled up as best I could and checked the weed hatch, everything fine. The canal did look quite shallow at this point so was the prop just hitting weeds at the bottom or is there a problem?
I knew the offer of a bottle of Scotch would draw them in!
Thanks and yes that's what I thought, getting some help from someone with experience rather than paying for a course could be the best way to go. Maybe offer nice bottle of Scotch in return for some hands on tutalage from someone who actually lives on a narrow boat is the way to go.
Thanks for all the quick replys. I suppose I haven't fully explained. I think one of us will eventually or even soon go on a Helmsman course. Our main concern is when we initially buy the boat and intend to head along the canal with hopefully very little or no locks to begin with, will we manage?
Hello, I'm sure this may have been asked before so I apologise as I am a complete newby to the boating world. My partner and me are due to buy a 58ft narrow boat subject to survey very shortly and we are wondering wether to attend a Helmsman course prior to setting off or just jumping on board and working it out ourselves? From the threads I have read on the forums there is a suggestion that it would be better to have the course done on your own boat. From my point of view, if you can go on a boating holiday without taking a course, (I believe that you just get a run down before setting off?) then surely you can work it out as you go along. Then again maybe I'm wrong and my partner the sensible half is right in going and getting some professionals tuition. All advise welcome please.
