I understand I got a few options to save power with the inverter such as:
Turn off inverter for overnight
Put a thermostat in the fridge and use a contactor to turn on inverter when temprature is above whatever setting it is to cool down again
Combine the two above
Reason I have opened this thread was that I was hoping that if you fork out so much money for an inverter in 2019 and buy a very common household fridge, Victron have overcome this problem as offgrid setups seem to be more and more common. Was hoping as it came up so often there might be a solution to this issue already..
Done a fair bit of look around the internet but can't see any real solutions. The issue is that the fridge having a very effcient danfoss 240v compressor it draws very little power (2W) before the compressor kicks in and by the time that would start up inverter goes back to sleep. Maybe on other inverter brands (such as Outback) you could adjust the inverter search period (when its on..) but as I see on Victron you cant.
Attached a screenshot how the options are on Victron AES (power save mode), the MSW seem to be only on when its in powersaving but this is only saving a few Watts however the actual search mode is a significant (about 70%) saving on power.
This won't be an issue during the summer but momentarily parked up in Durham and being cloudy the 1200W panels producing about a 100Wh a day which is nothing so keep the engine running a few hours a day to keep us charged..
