Creel
Posts posted by Creel
what spacer and where does it go as this is all I got with the engineIt doesn't really matter. Which is most convenient for the pipe runs?
I have just made a shaft for one of those
Richard
MORE: You've left the spacer out that goes between the input shaft and the bearing
hope this pic is OKIt depends on what your engine already has. Can you take a picture from the other side?
I'm interested to see if there is a hexagonal thing on the front of the fuel pump housing. Also, where is your current pressure gauge connected to?
If we work those out, I can tell you what thread you need for the sender
Richard
thanks RichardI did say I would see if we have a manual. I'll do that tomorrow
Basically, we find out where to connect a sender, work out the thread you need then you buy a sender and gauge as a pair
And probably work out how to blank off your existing pressure gauge take off
Richard
thanks will get some photo's tomorrow . the capillary one seams to come from the tops of the cylinder heads ? to a gauge in the cabinIt depends on what your engine already has. Can you take a picture from the other side?
Richard
can you tell me how to do this . what sort of pressure sensor would I need and where would I fit itA pressure sensor and an electric gauge
Richard
Hi has any one converted the Lister engine to electric oil pressure reader instead of the capillary . if so what would I need to do this
. Thanks that what I need to knowThe fuel filter on the SW2 engine in your other thread and is standard on SW, SR and ST engines, it is a paper element in a bowl FRAM C11941 PL. The old Crosland number is 489. Crosland have now been taken over by FRAM.
should have side diesel filter element as It has a filterWhether it had a temperature gauge originally or not it would be a good idea to fit one.
A diesel filter would be essential though and there should be one with replaceable element on the engine. A second primary filter before lift pump wouldn't go amiss, such as one here.
Hi some more questions . should my sw2a engine have a temperature gauge on it or some sort of over heat device on it . also what diesel filter will I need for it .
Thanks for the replys will get some pics of engine on . This engine has not been run for three years I can turn it over by hand when it is decompressed and the injectors are working .What do I need to do to recommission it .
Hi new to the site have been and introduced my self . so I will get to the point .I have got a
23ft taymar creel boat as a project sound hull needs a bit of wood work and paint . it has a Lister Sw2A water cooled engine . The jabsco water pump has been removed and a electric pump fitted for cooling has any one done this mod or seen it done all so I cannot find any information on my engine I know it is 15hp any one know where I could get a manual for it
Cheers Neil
Jabsco water pump for lister
in Lister
